Samsung DVDR120 DVD Recorder
Problem for Samsung DVDR120 DVD Recorder
DVD recoder not recording
By metallistan on Nov 03, 2006
My samsung dvd r122 recorder will not record, runs for about 25 seconds then spits the disc out with an error message prompting me to turn off the unit and try again.
Have done this but still refuses to record. I have also tried different dvd's.
Same Problem
Mar 30, 2008
-   want record (ec;0506)-   Guest
Mar 17, 2008
-   Another one here! Plays fine but "disc error" every time I try to record. Have tried several discs, all the correct type. Bought about 8 months ago from Argos who won't take it back as they say I could have bought it anywhere (unfortunately can't locate the receipt). See mention here of TDK disc, could someone enlighten me please as I don't have a clue what this is but would like to try it and see if it works. Thank you-   leah008
Mar 09, 2008
-   I used dvd-r disc to record but still doesn't work. It will start recording but after 6-10 sec, it says "System Error" on the TV and "Wait" on the DVD screen forever.-   bigbully
Mar 02, 2008
-   Was recording directly from a DV Camcorder using IEEE cable. Made one recording successfully. Then pressed stop. Received a "wait" display that never went away. Disconnected everything and cycled power. Now just get "system error" anytime I try to record via any means for type of DVD-r or RW.
Help-   zucktucker
Mar 01, 2008
-   will not rcord and there is no sound
-   Guest
Best Solution
posted on Oct 13, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Re-install & use T.D.K. disk. I did &it worked.
Solution #2
posted on Apr 03, 2008
Very Helpful)
Blitzspiel
Rank: Apprentice
Rating: 95%, 2 votes
I had this problem with my R120, it first wouldn't record and eventually wouldn't play, just gave either an error message or "wrong disc.' Then, another DVD player I own did the same thing.
What worked? I opened them both up and swabbed the laser lens with alcohol and then the clean end of the cotton swab. Now both work like a charm. I figure that all the dirty rental DVDs lowly drop dust and gunk and over a few months the build-up caused failure.
Just to be safe, I also used canned air to remove from inside the unit, around the circuit board and on the lens.
I'd advise leaving the unit unplugged for a day or more to let any stored energy drain and if you're not familiar with safety procedures, take it to someone who is.
Was this helpful?
Yes
No
Solution #3
posted on Sep 18, 2007
Helpful)
pseudonym
Rank: Master
Rating: 88%, 60 votes
Does that disc that you are using is working fine before? It might be that you are using a DVD+R that's why you cannot record movie to that recordable disc that you are using. The unit can only support DVD-R. You may try using that DVD-R if you haven't used it before. Hopes this helps.
Was this helpful?
Yes
No
Popular Solutions for Samsung DVDR120 DVD Recorder
Questions and Unsolved Problems for Samsung DVDR120 DVD Recorder
Do you recommend Samsung DVDR120 DVD Recorder?
Answer
Answer
I have a Samsung dvd-r120 recorder. The DVD player picture and sound freeze frequently while playing... (More)
Answer
dvd-v6800 i keep getting the message no signal when i want to record or play
Answer
Samsung DVD - SH893M - programme guide worked once but now doesn't!! Have I set it up wrong? It is a... (More)
Answer
When I recored on 8x disc I had no problem, but I am having trouble finding 4x or 8x. On everything... (More)
8 Other Users Have The Same Problem - Continued
Comment by aliina, posted on Jan 23, 2008
hello,
I have the same problem, it does-t play nor record any dvd-r or rw and it only plays cd-R that where burned in computer
thank you for any piece of advice
Comment by Koattie, posted on Jan 20, 2008
I am having this problem with Verbatim disks and I have been using these for a long time and today is the first time this happened. I just got done with one and it was fine. Now I can't get it to work I get the error after I start the record. tells be "system error is found"
Comment by Demesign, posted on Dec 06, 2007
I keep getting error message EC 0506
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
