Question about Microwave Ovens
I need to replace the bulb in my HITACHI MSE23 microwave. i can't get my hand in to do it, and i am v small. can't imagine how it comes out.
  • 108 Answers
You need to remove the cover. There are phillips screws on the back of the cover. Remove them and pull the cover up. The bulb is accessible. Replacements are availible from auto parts stores.
Ray
Posted on Nov 11, 2008
How do I replace the light bulb on my Sharp Carousel microwave - model R-8R51
Strip the microwave and you will see the bulb holder at the back you can use yo hand to turn itsideways
Sep 15, 2014 | Microwave Ovens
How can I unscrew the burned out 20w oven lamp from it's holder so it can be replaced.
Does it appear your can remove the window/cover that is over the bulb? If not, the back panel may need to be removed which can expose you to electrical shock especially if you are not trained to do so. I would imagine the cover should be able to be removed (unplug first) so the bulb could be replaced without disassembly.
Aug 20, 2014 | Emerson Mwg9111sl Microwave Ovens
How do i change the light bulb? Panasonic model NN-T945SF
Do you mean you want to replace light bulb for your microwave? If yes follow the instructions below;
  1. PLEASE UNPLUG YOUR MICROWAVE!
  2. Picture of your microwave with a phone or camera so that you don't forget how to assemble it back.
  3. Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
  4. Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
  5. Locate a small access cavity on the left.
  6. Remove the screw that is located near the front of the microwave door.
  7. Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
  8. Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
  9. Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
  10. The bulb connection should come right out.
  11. After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
  12. Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
I hope this helps to solve your problem.
Good luck.
Apr 09, 2011 | Panasonic NN-S541 Microwave Oven
How do I replace light bulb
Good luck.
Apr 08, 2011 | Daewoo Microwave Ovens
How to change microwave bulb
Hope this help in solving the problem, take care.....
Sep 16, 2010 | Microwave Ovens
Hitachi MSE23 - food will not heat
quite likely it is the magnetron bulb has failed . repair shop is best bet
Sep 06, 2009 | Microwave Ovens
How to change bulb
hi,
I imagine the whole outer cover has to come off, there are screws all along the back . Be extremely careful inside the microwave, stay away from the transformer and capacitor red wires, they store charge and are very dangerous.
be careful, wear leather gloves too
J
Jun 26, 2009 | Sharp R-963 Convection/Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
