Question about Hoover F5886-900 Steam Vacuum
Lost instructions How to use hand held for steps. Cannot get the water to flow.
The Hoover web site has all the owner's manuals posted for download, just go to this site and put the model number in, the next page will have a link to a pdf copy of the manual!
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Posted on Dec 02, 2008
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hand held vacume stop working after 1st use
go please to the web for instructional videos and maintenance help
God bless you
http://www.bissell.com/how-to-videos/
Jul 19, 2012 | Bissell 3594 CleanView PowerTrak Bagless...
I have a bissell pro heat 2 it will spray water through hand held pipe system but wouldnt spray from main capet brush area can you help me please
Ours would not spray water either, after messing with it for ages I discovered the round black housing that the tank locks into where the water flows out of the tank was loose. So I held the housing from underneath while seating the tank & it started working. It's very flaky & a lousy design. Good luck.
Jan 16, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Have water at the hand held but none out the bottom
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhklui
Nov 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Pro Tech Pro Steam Cleaner - no suction @ pump
Take a look at the Service Center Repair Manual (courtesy of Bissell New Zealand):
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
There's a (basic) diagnostic routine for cleaning solution flow (page 7). However, there's a step that's (somewhat) left out. If you follow the diagnostic and get no spray, then try to spray with the hand-held upholstery thing. If:
1) you can spray cleaning solution with the hand-held upholstery thingie, and
2) there's no pinching of the lines at the base of the unit,
...then your heater block is probably blocked. There's a Lower Handle Disassembly guide (page 20) which you can follow to get at the heater block. The input port on mine was blocked with lime, and quite clearly so (I live in an area with pretty heavy water). You can also take the heating block apart (page 8) to better clean out the flow channels, and apply some descaler. I suppose you could also just recirculate descaler through the input and output ports of the heater block, but I wasn't exactly equipped to do so.
If you can't spray cleaning solution from either the upholstery thingie or the main unit, you probably need a new pump. Word of advice: get the one with the METAL PULLEY on the end. The old ones had plastic pulleys which often failed or deformed to uselessness after a while. Since the pulley wasn't replaceable, you had to order the whole pump assembly. Bissell maintains a list of service centers in various countries / cities which can either repair your unit for you, or, considering the name of this website, sell you the parts.
Oct 07, 2008 | Vacuums
Hoover F7425-900 How to attach hand held cleaner
There is a round door at the top/front of the clear duct on the hood of the unit. You insert the hose there and then connect the small solution hose to a valve that is located on the right side (if you are facing the machine) of the machine, just ahead of the rear wheel.
Mar 21, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F5886-900 Steam Vacuum Logo
164 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
