Question about HP Pavilion dv1000 Notebook
My power on button doesnt always work well
I have an HP Pavilion dv1000 PC Notebook and when I try to start up my laptop, I have to press the power button at least 20 to 30 times. After 20 times or so if I press and hold for 4-5 secs it does seem to help. I am worried that eventually it will stay off permanently and that will be the end of my computer. Is this a fixable problem? Thanks, Linda P.
  • mailerone Nov 16, 2008
    If I had to start my laptop, I need to press the power button hard until my finger pains. Previously it would start with a single touch. If it hibernates, when ran out of power, I have a tough time restarting it. I had to press it a number of times and harder to on it. Please help me with my power button. How to repair it by myself ?
  • Charity Frederick Dec 31, 2008
    I had this problem too. I had the power switch replaced to the tune of almost $200. When I got it back, it worked one time. II called the service center and they told me it was a problem with hibernation. I disabled hibernation and still no luck.
    Now it won't come on unless I use the media buttons on top and press F8. The light on the power switch doesn't come on. Very frustrating to have to start my computer this way and I'm not sure how long it will last.
  • 186 Answers
This can be issue with the Power Button which might have worn out with repeated usage.
I recommend you to contact nearest Service Center and get the Power Button replaced as soon as possible.
Posted on Nov 18, 2008
It wont come on. it wont turn on
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for fifteen seconds.
Install either the battery and A/C adapter .Now just press the power button to attempt a boot into the OS.
Contract for further instructions.
Hope this helps.
Oct 07, 2011 | HP Pavilion dv1000 Notebook
Push power buttom, indicators blink on then right back off. Will not start
Try Power Flee...
take battery and power both OFF.. then press and hold the Power button for 30 seconds...
Both battery and power back ON... then try it again.
Feb 27, 2011 | HP Pavilion dv1000 Notebook
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Hp Pavilion dv1000 laptop wireless connection doesnt always work? Sometimes it shows that a connection is available but it wont connect. Sometimes it works fine but drops out right in the middle of what...
you might have to review the driver version of your wireless. try to check if there are updates that might fixed the bug. go to my computer, right click, manage, device manager, network adapters - under it move your mouse on top of the wireless, right click, properties, driver and check driver version and date. then go to your hp pavilion product support http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432999&taskId=135
and look for new version of network wireless driver might have. let me know if this doesnt fix the problem.
Apr 15, 2009 | HP Pavilion dv1000 Notebook
My HP Pavilion not started (no power)
incorrect shutdown with low battery will always cause problems....
first of all youre gonna have to put some charge into the battery...
then..press the power button to startup and wait for activity...lights , sounds etc..then press and hold power button until you hear pc shutdown.then restart...you may have to choose startup in option screen like start with last good config etc but now it will be back on.
Jan 16, 2009 | HP Pavilion dv1000 Notebook
RE: HP laptop no power
Give this a try -
1. Unplug all usb devices.(Printers, MP3 players, webcams, etc etc)
2. Remove the battery and power cable.
3. Press and hold the power button for 30sec.
4. Plug in just the cable (no battery)
If this doesnt work then it most likely needs a repair.
Also check the USB & power port for damage or if the charger jack is loose when you plug it in.
Jan 07, 2009 | HP Pavilion dv1000 Notebook
Turning on &sterio problems
Hi, my problem was that I had trouble turning my laptop on. It had been getting worse over the last couple of years. It was suggested that the power button should be replaced. While searching the HP site on how to do this, I ran across a solution that said to take out the battery, unhook anything else that might be connected to the laptop, and then press the power button for around 10 seconds to drain all remaining power out. Then put battery back in and try to turn on. It worked! My laptop now turns on and off just fine! Hope this can help someone else....Linda P
Nov 07, 2008 | HP Pavilion dv1000 Notebook
Have you followed the recommendations on HP SITE
If the screen is blank they suggest disconnect the power, battery, and reset the memory modules.
May 25, 2008 | HP Pavilion dv1000 Notebook
Problem with seaker
please help me, i need sound drivers and bluetooth drivers from hp pavilion dv1000
please send to my email unitech88@gmail.com
Apr 20, 2008 | HP Pavilion dv1000 Notebook
Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
R-
Nov 05, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
