Question about Panasonic Lands Phones
KTG4500 Phone key board will not work, can answer the phone, can not put on hold a call or check voice messages from main unit.
5 Suggested Answers
SOURCE: Memory Full?
I unplugged my power supply cord from back of phone and replug it again, I found there were in fact four messages. After I deleted them I was able to use the memo button again. So perhaps this willhelp you, too. Ackey320
Posted on Sep 02, 2007
SOURCE: Changing message
I am a new voluntary worker to the charity. The operating manual is lost. I like to change the date and time on display. Can you help!
Posted on Jan 30, 2008
SOURCE: cannot record new answer phone message
push the mute button on your cordless uniden phone,and you will see the number 5 come up on the phone display.then hit the number 6 and when you hear it begin to beep record your message
Posted on Sep 14, 2010
  • 225 Answers
SOURCE: THE ANSWERING SYSTEM WON'T RECORD
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Posted on Mar 30, 2011
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Jul 06, 2012 | RCA 25414RE3 Corded Phone
I don't know how to set up voice message
If you mean setting up voice mail out-going message, then see below (for AT&T cell service). The phone will dial the voice mail center for you after you set it. Then it will check the number of messages on the system. Press Menu > Messaging > Settings. Then select Voice Mail and enter the phone number for the call center. Then press the AT&T button to exit.
To listen to the messages, press and hold 1 or press Menu > Messaging > Voice Mail. Then the number set above will be dialed.
To set up the voice mail box, start as you would for listening to the messages above. Note: you must use your wireless phone and be inside the AT&T coverage area.
To set up your voicemail box:
1. Follow the prompts to create and enter a 4- to 15-digit voicemail password.
2. Record your name and personal greeting, then press the # key
3. After completing the setup process, press * to return to the Main menu.
See http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&ft=browseTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=52653&isSrch=Yes for more information.
For another provider, see their documentation.
To create a memo for yourself, press Menu > Tools > Voice Memo (or if using the advanced menu, Menu > My Stuff > Tools > Voice Memo). Then press Options > New (or Create New, if you have created one before). Press Re-rec to record and pause to momentarily stop recording. Press the AT&T button to stop recording. Press Play to play back a memo and the AT&T button to stop play-back.
I hope this helps.
Jan 29, 2011 | Pantech breEZeTM Cellular Phone
How do I set up voicemail? New phone, mailbox says it is full, how do I delete messages?
  • Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
  • 2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
  • 3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
  • Oct 04, 2010 | Samsung Hue (SCH-r500) Cellular Phone
    How can I check my boyfriend's TMOBILE voicemail from my phone
    Step 1
    Dial your phone number from the phone you are using to check your voice mail. Let the phone ring until the voice mail message begins.
    Step 2
    Press the "*" key or the "#" key while the message is playing. One of these two keys is usually the key that activates access to your messages. This will work for most answering machines and voice mail services, although some may use a different key code .
    Step 3
    Enter your password or passcode. For most systems, this will be a four-digit number that is keyed in and will sometimes be followed by the "#" key.
    Step 4
    Listen to your messages. Usually, unheard messages are played back first, followed by any saved messages on the system. Systems vary as to whether the oldest or newest unheard messages first.
    Feb 26, 2010 | Motorola Mobility Clutch i465 Cell Phone
    The voice message waiting LED light flashes and there are NO NEW MESSAGES. I have reset by holding the mute/find hs key on the DCT756 base model. The flashing light will not go away. Any solution for this?
    your phone may be equipped with voicemail call your own phone number to see. mine is and that is why mine flashes. and the answering machine does not usually work with voice mail. i'm not sure why but i always have voicemails and no messages on my answeriong machine.
    Nov 16, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
    I have a panasonic Cordless phone and can't remember how to remote access it?
    Using the answering system
    remotely
    Dial your phone number from a touch
    tone phone.
    2 After the greeting message starts, enter
    your remote code (page 59).
    LThe unit plays back new messages.
    LAfter playing back new messages,
    the voice guidance starts.
    3 Follow the voice guidance as
    necessary.
    4 When finished, hang up.
    Note:
    LYou can ignore the voice guidance and
    control the unit using remote commands
    Voice guidance
    During remote operation, the unit’s voice
    guidance prompts you to press {1} to
    perform a specific operation, or press {2}
    to listen to more available operations.
    Operations are presented by voice
    guidance in the following order:
    – Play back all messages
    – Play back new messages
    – Record your message
    – Erase all messages
    – Record your greeting message
    Note:
    LIf you do not press any dial keys within
    10 seconds after a voice guidance
    prompt, the unit disconnects your call.
    LIf less than 3 minutes of recording time is
    available, the unit announces the
    remaining recording time after the last
    message is played back.
    Remote commands
    You can press dial keys to access certain
    answering system functions without
    waiting for the voice guidance to prompt
    you.
    Key Remote command
    {1} Repeat message (during
    playback)*1
    {2} Skip message (during
    playback)
    {4} Play new messages
    {5} Play all messages
    {7} Recording a greeting
    message
    You can download the full manual at
    http://www.retrevo.com/support/Panasonic-KX-TG5776-Telephones-manual/id/1074bh748/t/2/
    Please make sure to rate this solution. Thanks.
    Jul 23, 2009 | Panasonic KX-TG5776S Cordless Phone
    Retrieving messages over phone
    when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
    Apr 14, 2009 | Lands Phones
    No instruction manual
    On the handset that is on the base is the one you need to use to set the time and date. It will also clear out the CL on answering machine.
    On the handset without pushing talk hit the flash key. A message will appear on your phone and it says Answering machine. You can listen to all the options but to set time and date ---push the 8 button.
    Set your time by using the phone keys such as it's 09:53 then look up in the right corner and use the + arrow key to set AM or PM. Then hit the # key. Then in the upper right corner it will say Mon---use the + arrow key to set the day. Then hit the # key. The message on your phone will say the day is and then the time is. Then hit flash. Then you can check your answering machine and see if that worked. This took me some time. I would not buy another phone like this again.
    Mar 06, 2009 | GE 25952EE1 Cordless Phone
    S2200 freedom phone
    Bigdar50,
    According to SW Bell:
    Setting Up Your Voicemail:
    1. Press and hold the 1 key.
    2. Follow the voice prompts.
    Checking Your Voicemail Messages from Your Wireless Phone:
    Checking Your Voicemail Messages from Other Phones:
    1. Dial your 10-digit wireless number.
    2. Press the * key when you hear your personal greeting.
    3. Enter your personal passcode.
    4. Follow the voice prompts.
    If you would like to have a Security Password for all Voicemail calls, from the Main Menu:
    2. Press 4 for Personal Options.
    3. Press 2 for Administrative Options.
    4. Press 1 for Password and follow instructions to turn on your password
    Hope this helped,
    Jem
    Sep 05, 2008 | Southwestern Bell (S60802)
    Lands Phones Logo
    69 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
