Question about RCA HD52W58 52" TV
Coax Cable My television does not have a coax cable input
  • emontano77 Nov 10, 2008
    how can i convert my TV to connect the coax cable??
    is anyone going to help me??
    Scholar:
  • 146 Answers
You need a cable box if you have channels that are digital (mustly the channels above 74). If you do not have those higher channels you can use a vcr or a dved player that has a tuner in it. Put the cable into the vcr and then use the Video and Audio jacks (A/V jacks) and the back of the vcr that say "OUTPUT" and hook them up to the same type of jacks on the back of the tv that say "INPUT".
Posted on Nov 10, 2008
How to set up vhs taping
Most VCRs need to be connected in a daisy chain or a splitter from your input source. (You may need a tuner with some VCRs these days; either a digital to analog converter for a VCR with an NTSC tuner or a different tuner source.)
If you have analog cable or a cable box with coax out and a VCR with an NTSC tuner, use the daisy chain method. Connect the incoming cable or the coax out from the cable box to the VCR's coax input. Then connect the VCR coax out to the TVs coax input.
For a VCR without a tuner, you'll probably find a RCA composite video line in option on the VCR. Connect your cable box or converter box composite output to the VCR composite in. For an OTA source, you'll need a splitter to send the signal to both the TV and the converter box.
Most TVs do not have a video output option.
I hope this helps.
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Where does my coax cable plug into this tv? I can't find the cable jack.
In between your composite inputs and audio inputs on the back, there should be a coax plug that says antenna/cable. Plug it in there and you should be good.
May 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The analog imput is completely broken can it be fixed?
IF YOU ARE TALKING ABOUT THE COAX INPUT, YES IT CAN BE REPLACED BUT you have another option----use a cable box and input it into one of the video inputs, this bypasses the coax input..got it/
If you want to fix the coax input it can be done, let me know with a comment and I will assist here.
SD TECH
Aug 17, 2010 | RCA R52WH73 Projection Television
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
Where is the cable connection on my tv
There are usually two types of cables that connect to your tv-- coax and RCA. Cable usually uses the coax style, but some modern tvs don't have a coaxial input, which means they probably have RCA jacks. Therefore, you will probably have to find an RF modulator or the like that has a coax cable "Cable" input and RCA (yellow, white, and red plugs) output. These should be able to connect your tv to cable. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Protron PLTV-32 Television
My 42 inch sylvania plasma tv does not have a coax connection, so how do i hook up my cable to the audio/video connection? i know there is an rf converter to transfer audio/video to coax but i really...
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Aug 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Buying one online and need to know if there is a coax input?
This unit contains both the NTSC and ATSC tuners available using a coax connector on the back.
Dan
Mar 25, 2009 | Sharp Televison & Video
RCA HD52W58 52" TV Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
