Question about Microsoft Computers & Internet
I have Verizon FIOS, but I want to be able to use Outlook
I have FIOS, but I want to be able to use OUTLOOK, since when I link onto email addresses from websites it defaults to OUTLOOK. What happens is that the email I send goes to the outbox, but is not sent since it does not show up in the sent box. Is this a POP issue? Thanks
First you need to configure your outlook incoming mail server and outgoing mail server normally you can get it from your isp provider for verizon normally it is incoming.verizon.net for incoming server and for outgoig it is outgoing.verizon.net
Posted on Nov 15, 2008
Tip
I cannot access my Verizon mail _ Verizon.net server responded: Authentication...
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is MyMail@verizon.net , then try first putting id MyMail@verizon.net , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is MyMail@verizon.net.
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
on Mar 12, 2010 | Microsoft Office Outlook 2007 for PC
Dir 615 outlook
Check with your Internet service provider which ports are open for outlook. If you do a Google search - like Verizon FIOS outlook ports - it will give you the correct ports.
Dec 09, 2013 | Computers & Internet
I would like to migrate my outlook express email and windows address book over to microsoft outlook... I know there will be no problem bring over all my email and email folders, however as you probably...
For that you need to import it in 1 file.
Open outlook express then go to file menu then import ->address book.
Then save it to desktop then you can export in microsoft outlook with that file.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 15, 2010 | Computers & Internet
I am trying to set up Outlook to send and receive mail. receive is working but sending is not. my email address is mike.reinking@verizon.net
make sure in you otgoing smtp you put coreect address and also check you select my server require authentication. als check you have ant antvirus programme which is blocking the mail.
Jan 19, 2010 | Microsoft Office Outlook 2003 for PC
A Verizon FIOS tech deleted my Outlook Express and my Address Book which has over 600 addresses in it, can it be retrieved?
You may find your data files are still on the disk and only the program files have been removed. You should try and find your data files and make a back up of them before you try and restore outlook express.
Once you get Outlook Express working again you should be able to restore the data files.
There is a great description here about how outlook express stores it's data. As usual Microsoft seem to have gone out of their way to make it complicated where other products just have a file or two.
Read the article and perhaps do a bit of googling on your own and I think you will figure it out.
Sep 26, 2009 | Microsoft Outlook Express
Since our switch to FIOS we are unable to email from the machine. The log says "invalid from address" but this didn't change during the conversion. Any thoughts?
You probably are using a POP3 mail client like outlook or incredimail or the like.
You'll need to change the profile IN that mail client. Relatively simple to do. The information is INCOMING.VERIZON.NET and OUTGOING.VERIZON.NET.
If you had DSL service with them previously then it may be that your screenname was NOT scrubbed across into the FIOS network. In this case you'll need to contact the tech support people (good luck) and ask them to scrub your old id across.
To check to see if the s/n (screenname) was deleted. Go to verizon.net and attempt to login there. If your e-mail pops up then your s/n exists and it's merely the pop3 mail client settings that are botched.
Lemme know.
Jul 17, 2009 | Toshiba (GM1030) for E-Studio 200L Print...
Gateway puchased with installed Windows XP and microsoft outlook express in 2004 (that is Microsoft outlook express 6)....have Norton best package...have Verizon as internet server....and have...
I think the problem is from your sender. Is the message sent from a personnel email address or from a corporate address? I asked because where I worked, we could make rules to send messages and sometimes those rules were causing that type of problem.
May 28, 2008 | Gateway Computers & Internet
I use Outlook Express on Windows XP... Can I snyc this?
Outlook Express - no software included with Palm devices but There is third-party software to synchronize the email and Windows Address Book from Outlook Express to Palm OS devices. Here is a relevant link: http://www.livepim.com/expressmirror/index.htm - address book conduit to mirror the OE address book to Palm Desktop
Sep 12, 2005 | Palm Zire 21 Handheld
Computers & Internet Logo
742 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
