Question about Seca 700KG Balance Beam Scale With Wheels, 220 Kg Max
How do I calibrate the scales?
The scales are each about eight (8) pounds off. We have two (2) in the locker rooms, one for the men and one for the women. Can you give me instructions or do I have to have a service person come by the Spa?
I have a Penn Scale CM 101. On the net weight it registers -1.23. WE can not get it to zero out. Any suggestions?
1 Have the scale turned off
2 Turn it back on
3 While it’s counting down press the Tare button
4. Asks for passcode enter 0000
5 Keep pressing Tare until it says Load 30 pounds
6 load the thirty pounds
7 turn scale off
8 remove 30 lbs
9 turn back on
I hope this works for you as well
Sep 16, 2017 | The Health & Beauty
Is my scale calibrated. When I turn it on it first shows 8888 7/8, then it 0/0g
Take a ten pound bag of sugar and calibrate the scale to read 10 pounds.
Oct 30, 2014 | Salter 3007 Aquatronic Digital Scale
Resetting my accur 8 digi scale cp-1000
please preform the following procedure
Calibration
1. Place the scale on a leveled surface & turn off the scale.
2. Press and hold the "MODE" key and ON/OFF key until the LCD
displays a random number.
3. Now release both keys and press the ON/OFF key once. The
display will read "CAL" and then "1000.0".
4. Place a 1,000g weight on the center of the platform and wait 3 to 4
seconds. The LCD display reads "PASS", then "1,000.0g". Remove
the weight and turn off the scale.
5. Calibration is complete and the scale is ready for use.
check this link for manual:
Untitled Page
Apr 25, 2014 | Health & Beauty
Vivitar scale accuracy
Why do you think it should be off?
Did you put on a known weight? Personal scales, come with a certain tolerance the is much more then the digits suggest. Most of the time the tolerance is printed in the manual. even 1% is a least 2 pounds plus or minus for a full grown person.
There is one plus in this, the deviation, is most of the time the same over a long time. So don't look to the absolute figures, unless poi did calibrate, just see if you are making progress over time.
Feb 14, 2014 | Vivitar Cameras
I am looking for a calibration guide for a Triner 1870x-fb
I found a manual that has calibration instructions for this scale.
Apr 10, 2010 | Health & Beauty
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Programming scale to display in pounds
ITS YOUR SCALE BOARD! <-- I am also an NCR Technician (Now Sales and Technician)
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Dec 29, 2008 | NCR 7875
Scale not accurate
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Nov 10, 2008 | Taylor 7321 400 Pound Lithium Scale
Seca 700KG Balance Beam Scale With Wheels, 220 Kg Max Logo
1,842 people viewed this question
Top Seca Health & Beauty Experts
Jaye t rock
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
