Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch
Problem for Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem...
Can't get connected to the internet
By Rowena on Nov 03, 2006
I have recently bought a new Trendnet modem/router, so as to get wireless from our tiscali internet. However, even though we all get strong signal from our wireless cards to the router, we can't get it to connect to the internet. I have tried going into 'run' and checking the ip address etc but they don't match the ones I have been told I should have. I have no idea how to change these ip addresses and Tiscalis only solution is to restart the computer which doesn't work. Please help!!
Same Problem
Nov 22, 2007
-   cant connect to the internet via usb adaptor i have got one pc connected to modem router and the other by the usb . i have tried wzg , re installing it i got good signal strength i checked the usb was working via device manager still won"t connect have u any advice-   Guest
Best Solution
posted on Nov 03, 2006
Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5927 votes
As usual technical dept in all ISP's are useless and unhelpfull especially if it's not a supplied modem.
(p.s. the ip address they are going on about is probably your routers address and not the ISP's address)
Anyway; you will have to get into your routers settings page, as you may have to set it up manually as I had to for a friend who is also with Tiscali as the router cannot obtain an ip address automatically from Tiscali.
Make sure you are connected to the router via the RJ45 network cable (Normally Supplied)and then Normally you type in something similair to 192.168.2.1 or 192.168.1.1(check your manual for this), in your internet browser eg internet explorer.
Then go through the settings using the routers settings Wizard and manually input the following.
Virtual Circuit Identifier - VCI38
Virtual Path Finder- VPI0
Encapsulation Mode VCMux
Authentication Type CHAP
Protocol RFC 2364:PPP over ATM (PPPoA)
Modulation Type G.DMT or Auto
Primary DNS Server 212.74.112.66
Secondary DNS Server 212.74.112.67
Save settings.
Try accessing internet while you are still wired, if you can you know the ISP's settings are ok and you already know each PC can access the router, you should be away.
Comments:
Nov 03, 2006
- Can i assume that you have setup your username and password in the routers settings also, as it will not connect otherwise, because when online with a router it is 'Always on', unlike when you get the supplied modem , you normally click connect to get online.
Nov 03, 2006
- Also please don't forget to rate this solution as we need to know if the information provided is useful or not.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 25, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sandrew,
I don't know about the original guy, but your post has put an end to a 20 hour long process of connecting my 2-Wire 2700HG-B router/modem to Tiscali.
Not even Tiscali customer services could help, they where pretty useless tbh.
Thanks very much for the information,
Rob
Solution #3
posted on Feb 24, 2007
Somewhat Helpful)
Stealf
Rank: Apprentice
Rating: 0%, 0 votes
I'm having a similar problem with tiscali and a 2wire HomePortal 1000. I get "Can't connect to configuration server" but most ordinary websites on port 80 work fine but anything like logging in to a https site or doing ajax stuff fails.
I notice the automatically retrieved dns servers are 212.139.132.7 and 212.139.132.6 and if I change them to 212.74.112.66/7 I lose the connection altogether. The manual setting of dns servers asks for a domain name which I don't know. I've tried setting it to tiscali.co.uk and leaving it blank.
Was this helpful?
Yes
No
Popular Solutions for Trendware TRENDnet TEW-435BRM
Questions and Unsolved Problems for Trendware TRENDnet TEW-435BRM
Do you recommend Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch (NETWTW435BRM)?
Answer
Answer
Using Vista, and Belkin F5D7234 Router. I"ve called Belkin tech support who helped change some... (More)
Answer
the status light keeps blinking, i can not connect to the internet
Answer
I have a wireless router, with 4 LAN outlets. I have two in right now, and only the connection to... (More)
Answer
i need help to get an additional laptop connected to internet using existing router i wanted to... (More)
Answer
the router tew435 is blinking power&status but nothing is happening
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Trendware TRENDnet TEW-435BRM...:
Top Router Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
