Question about Photography
V-0551 Upper leg clamp broken.
Clip which prevents leg section separation is missing.
  • BRIAN REISS
    BRIAN REISS May 11, 2010
    NEED THE MAKE OF YOUR TRIPOD TO BE ABLE TO REFER REPAIR PARTS. V0551 DOESN'T TELL ME MUCH. REPLY TO ARCLIGHT1217
SOURCE: Broken Quick release tabs
Broken quick release on a Manfrotto 728B digi. What is the best and most economical way to fix? Is there a repair or service provider near Somerville, NJ 08876?
Posted on Nov 23, 2008
morgan747
  • 9 Answers
SOURCE: Leg clamp tightening adjustment on a 055 tripod
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
Posted on Mar 20, 2009
  • 215 Answers
SOURCE: Broken leg clip on Manfrotto Modo 785B
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
Posted on May 11, 2010
  • 685 Answers
SOURCE: Broken leg clamp, Where can I buy a replacement part?
Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part
Posted on Jun 22, 2010
  • 175 Answers
You can oredeer parts from
www.bogentripodparts.com
Posted on Nov 05, 2010
I have the Sunpak 6000PG..One of the leg sections does NOT hold when clamp is in place. All other sections work fine it's only one of the ones that contacts the ground. HELP??
Sunpak 6000PG what ? From the rest of your post, it appears to be a tripod. I am confused when you refer to 'one of the ones that contacts the ground' - all legs on a tripod should contact the ground.
Be that as it may, if the leg clamp is broken, it may not be financially viable to have it repaired, and you may wish to replace it with a newer, sturdier model that will stand up to rough treatment.
Oct 06, 2017 | Sunpak Photography
NEED A CLIP TO REPLACE BROKEN CLIP TO EXTEND THE LEG ON THE TRIPOD.
You probably will not find one, as the tripods are imported and very low cost and they do not stock parts.
However you can buy a hose clamp like what you use on engine hoses put that around the broken leg and tighten it down.
Clear skies
Aug 10, 2015 | Optics
I have a Manfrotto 685B monopod that I have had for about a year. Recently I noticed that it has gotten very hard to extend or retract the leg sections of pod. I looks like there is a wax substance on top...
If it was second-hand or pre-owned, the previous owner may have applied some form of lubricant to it. From a look at the images on the Net, it appears that the upper sections are adjusted by twist grips. If this is so, just unscrew them and separate the leg sections carefully, after which they can be cleaned. There may be a bevelled collar within, to grip the section - be careful with it.
The bottom section seems to have a standard lever lock. There should be a couple of screws holding this to the middle section - loosen these, then slide the leg portion out and clean it as well. When re-assembling this part DO NOT over tighten the screws - just enough to prevent the locking collar from moving.
Apr 08, 2017 | Bogen Communication Bogen / Manfrotto 685B...
Broken leg clip on Manfrotto Modo 785B tripod the head is non-removable on this model and I don't want to have to replace whole tripod so is there somewhere I can buy a new leg clip or get it...
R785,203B
Regards
PDG
May 09, 2010 | Photography
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
How do u disassemble forks
Here is a diagram of your forks:
http://216.37.204.203/Yamaha_OEM/YamahaMC.asp?Type=13&A=140&B=28
Assuming you have already removed your fork cap, you will need to remove the clip # 5 and the bolt # 18 then in a slide hammer type action, pull the upper tube out of the lower tube. There is a washer underneath the fork seal that will pull the fork seal out with the upper tube, so you have to compress the fork tube, then give it a good yank to pull the seal and separate the tubes.
A couple of tips here. First, to loosen the fork cap, loosen the top triple tree pinch bolt at each fork leg before removing the forks from the bike, then loosen the fork cap. You don't have to take the cap off at this time, but break it loose. It is very difficult to hold the fork tube and prevent it from turning once the fork is off the bike and out of the clamp. It is much easier to break it loose and leave it finger tight before dropping the forks out of the triple clamps. The key thing to remember is loosen the pinch bolt before attempting to loosen the cap. The pinch bolt applies extra pressure to the cap and can complicate the process of loosening the cap if left tight.
The other tip would be to use a 3/8" air impact wrench to loosen the allen bolt in the bottom of the fork leg. The internals will want to spin if you try to do it by hand.
Oct 03, 2009 | 1994 Yamaha FZR 600
How to replace fuel filter on a Mercury Village '95?
go here for help on villager issues
http://autos.groups.yahoo.com/group/villagerquest/
It's unde the hood, on the firewall, on the driver side.
Fuel Filters In-Tank
Removal and Installation
The in-tank fuel pump filter is not serviced separately. To service the fuel pump filter, replace the fuel pump (9350). Refer to the procedure in this section. In-Line
Removal
The following illustration is an exploded view of the fuel filter (9155).
Item Part Number Description 1 9K299 Fuel Filter Upper Hose 2 9A335 Fuel Filter Bracket 3 — Fuel Hose Clamp 4 9C323 Fuel Filter Lower Hose 5 9155 Fuel Filter 6 — Fuel Hose Clamps
  1. Relieve the fuel system pressure. Refer to the procedure in this section.
  1. Remove the fuel hose clamps.
  1. Disconnect the upper and lower fuel filter hoses from both ends of the fuel filter. Plug the fuel hoses to prevent leakage and contamination.
  1. Remove the fuel filter from the fuel filter bracket (9A335).
Jun 05, 2009 | 2001 Mercury Villager
ART055 manfrotto pro tripod
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Feb 04, 2008 | Manfrotto 055NAT3 Tripod
Photography Logo
43 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
