Question about Procom ML300HGA Heater
Infared burners with flame at the tops of them
I have a 5 burner infared heater . I think it is a cozworld made like a procom manual control 2 years old . it works good when i turn it on i can see some flames above the placks that are glowing i was wondering what i could do for this or is this normal ? i have blowed it out with air twice and it has not helped. thinks Dennis R
  • 188 Answers
This may mean that the plaques are cracked, if they are cracked you cannot repair them, you would just have to replace them. You can contact Master Parts they may be able to help you. You can contact them toll free at 800-446-1446. Thank you
Posted on Feb 08, 2010
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
I have a Richmond 40 gal water heater model# 6G40PVW-40PF manufactured 5/2010 and it wont't stay lit. I don't have the owners manual as we purchased our home in 12/2011 and it was a foreclosu
Well I you have the problem resolved by now, but I will answer anyhow. This just happened to me yesterday with the same water heater that you have. My problem was that the flame sensor was dirty and not picking up that the burner was lit, so it shuts everything down and goes into lockout mode. I had a similar problem with my furnace lighting system. It is called flame rectification. What actually happens is the flame itself allows a small current to flow through it, so the flame sensor actuall makes electrical contact with the burner. The control senses this connection and knows then, that the flame is on. If it doesn't sense this connection, it thinks the flame is out, so it must shut off the gas valve to prevent a possible explosion. Take your burner out and clean up everything in there, being careful not to break the small glass bulb inside, which is another safety device. Fine emery cloth of a wire brush will clean up the flame sensor good. Also wire brush the burner itself, since this is the other end of the rectification circuit.
Apr 01, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
How can I adjust the flame? I have the CGCFTP and one side of the flame is higher (alot) than the other side. It's burning the top of the metal insert.
Normally, you can raise and lower the flame height, with the Control Knob (Wider the white stripe the higher the flames. Narrower the stripe, the lower the flames). But, I don't think that's your problem. From your description, it sounds like the burner may be clogged or there is a air shutter control problem on the open end of the burner. This controls the air to gas ratio. Also, depending on the age of this Compact Classic Firebox and whether or not annual maintenance was preformed regularly, the burner may be shot entirely. Since DESA International, who made the Comfort Glow line for Lowe's, went out of business in 1999, we know the heater is at least 2 years old, minimum. Although, I suspect yours is an older model, based on the Model Number you provided. If you feel comfortable troubleshooting it yourself, I have provided a link to your Owner's Manual, in case you have misplaced yours. You can down load and print it for future, as well as for any parts you may need.
http://www.desatech.com/manuals/Fireplaces/model_CGCFTP_manual_111044-01L.PDF
If you don't feel comfortable repairing it yourself, contact your propane provider. As most propane providers also do service and repair for this type of Vent-free Gas Fireplace.
Hope this helped to steer you in the right direction.
Mar 17, 2011 | Desa International CGCFTP Compact Heater
My heater lights but the flame is blue on the bottom and a yellowish white about 2 inches after. Why is it not all blue. This set to natural gas.
This could be caused by an improper gas to air mixture. Generally, it's an indication the air indicate valve is clogged with dust or lint. The air intake valve is part of he burner, It can be seen as an opening where the gas line from the control valve attaches to or enters the burner.
Turn the heater off and remove the front cover. This will give you access to all the inner workings of the heater. Using a vacuum cleaner that has a hose and crevice tool attachment, vacuum the burner(s) and the air intake valve I described above. While you're at it, clean all of the interior of the heater ( a brush attachment works well for this). Blowout the pilot tip with canned compressed air that has a straw nozzle (like you clean your computer with). Reassemble the heater cabinet and light the pilot, then the burner(s). Do the flames appear to be blue with yellow tips? If so, you've solved the problem and also, what's called "Annual Maintenance". Which normally is done in the Fall, before firing up the heater for the Winter. Do this every year and you should have years of trouble free service from your heater.
Let me know if this solved your problem.
Mar 10, 2011 | Procom Heating & Cooling
I have a PROCOM model ML300TBA, two years old. Here is my problem: Pilot lights fine. Burner lights fine. When I go back the next morning, often times it is out. Burner and pilot are out. It will...
You could try cleaning up the thermocouple with steel wool. Some manufacturers call this a flame generator as well. Any how make sure it is clean and positioned in the top center of the pilot light for best signal. This is only speculation as these are common problems that will arise on heaters in general. This also turns the gas to the burners and pilot light so thats why to start here first. Hope this helps you out.
Dec 23, 2010 | Procom ML300TBA Heater
I have a vanguard propane wall heater, 5 burners Model#vp2600c that the two middle burners flame goes above the burners and now has started to burn through at the top, what all parts do i need to replace?
The burner and anything else that was damaged. You might want to get the advice of a local professional. Remember, this thing runs INSIDE your home, where you live, eat and sleep. You want it to be safe, my friend.
Thanks for your question at FixYa.com
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
My blue flame heater has yellow tipped flames?
yes - it needs to be serviced on a regular basis. It will have an accumulation of dust in or around the burner
Dec 02, 2009 | Procom ML300HGA Heater
Procom ML300HGA Heater Logo
166 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
