Question about OKI C3530N Color MFP Printer
Okui 3530 toner sensor error - OKI C3530N Color MFP Printer
  • Anonymous Apr 06, 2009
    sameprob -- good advice- problem sorted - thanks
Turn off eq - open and remove the drum with the color cartridge in locked position still in place - on the drum on the cartridge lock side you will find a small (1/4 ") rectangular "window"...with the catridge in locked position the window should be open so you can see the sensor...when the cartridge is unlocked the window should be closed...so with the cartridge locked, using a tiny pointed object (paper clip), gently move the panel up or down to the open position (mine moved up)....replace the drum with cartridge...make sure it is set properly...close up everything and turn eq back on....you may have to do this two or three times to make sure the window stays open when the lock is engaged...but this is what the "tech"(salesman) did...good luck
Posted on Nov 18, 2008
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
We have a Canon iR 2270 and get the the Error message E000024-0001. What might the problem be? How do i solve it?
if e000024-0001 is comming plz clean the toner box in which magnet roll is runing then try you machine is not give this e000024-0001 singnal.
Dec 28, 2010 | Canon IMAGERUNNER 2230 Copier
E000024 error in my canon 3530 what can i do for it please help me
There doesn't seem to be an E024 in the error table. Must be something in the drum /toner area though.
Ensure all drums and sensors are clean.
SALT Sensor sometimes causes strange error codes.
Oct 06, 2010 | Canon imageRUNNER C3200 Copier
Ri-3530 "image cycle" error when printing
Check your toner cartridge, it is trying to add toner.
Mar 11, 2010 | Kyocera RI-3530 Black and White Copier
Canon ir 3530
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Ir 3570 error e000024-0000
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
0000 The connection detection signal is absent
continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller
PCB.
0001 Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
When the disconnection of the wire used for
detecting the connection of the toner level sensor
has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop
cassette feeding).
has been detected for 12.5 min without
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
interruption.
Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
Jun 15, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Panasonic DP 3530 printer keeps saying Machine error E03-40
E3-40 is the copy density sensor on the drum unit. Toner is probably dropping from the drum unit onto it. You have to remove the drum to access the sensor.
Apr 13, 2009 | Panasonic Workio DP-3530 Copier
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
Need to be fixed
either the toner output voltage is inaccurate,poor contact,no contact at ll or the toner sensor is faulty replaced it.
Feb 15, 2008 | Kyocera RI-3530 Black and White Copier
Light copies
toner sensor not set properly, or the toner sensor is bad. what is the make and model, it would help to solve your problem faster.
Oct 24, 2007 | Kyocera RI-3530 Black and White Copier
OKI C3530N Color MFP Printer Logo
2,627 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
