Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
Kenmore 790 Oven Door will not close tight enough
I have a Kenmore model no. 790.96212400 SN: VF44033128.
Does anyone know if the hinge problem on this range is covered by any recalls or such?
Thanks in advance...
  • Anonymous Dec 01, 2008
    I also have this problem and it call for upgraded hinges which are not covered by a service flash 22-777 last sears product I will purchase
  • 126 Answers
SOURCE: Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Posted on Nov 23, 2007
SOURCE: Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Posted on Dec 21, 2007
  • 148 Answers
SOURCE: Kenmore elite 790 79363400 dual fuel oven door does not close all the way a
if your locking it to make the light goes off it sounds more like the light switch on the oven needs to be replaced
Posted on Jul 08, 2008
  • 4 Answers
SOURCE: Kenmore Oven Door Lock Stuck Out
We had this same problem. We found that pushing the censor button/switch on the upper left rim of the oven's inside moved the lock and made it capable to unlock, or purchase a pizza pizzaz.
Posted on May 25, 2009
  • 31 Answers
SOURCE: I have a Kenmore Elite Gas Range. #790 series.
Possibly a malfunctioning electric gas valve. The electronics may be sending the message to open that valve, however it could be stuck, clogged or, worse, the electric servo that manipulates it could be fried (no pun intended).
Do you have your exact model #? {Not serial} I can research where to troubleshoot a valve problem or an electronics issue.
Posted on Jan 05, 2010
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Kenmore 790 electric range
Clean well the bottom or you have broken hinge. Replace.
Mar 30, 2014 | Kitchen Ranges
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Oven door
dat, If your model starts with 790. there is a service flash regarding the hinges. Oven door not closing all the way. Affected model serial numbers VF-428xxxxx through VF-434xxxxx. There is a hinge kit for it, part number depends upon your full model number. You may want to call Sears and inquire about the service flash, you should be covered. Catriver..post back.
Mar 04, 2007 | Kenmore 96213 Electric Kitchen Range
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
266 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
