Question about Weather King 10AJA3601AH Air Conditioner
A/C Size I have a old Tappan condensing unit . Can you tell me what tonnage it is? Model # CM-36-43-S Serial# 77 D 29235 Thanks
    Scholar:
  • 66 Answers
This appears to be a 3 ton unit. The number 36 represents 36000 BTU`s. That would be 3 tons.
Posted on Nov 10, 2008
Can you tell me the tonnage of this unit...it is a r22 condenser/rheem or ruud
Unit was shipped to Ferguson Distributors. The 757 at the end of model indicates R22. Manufacturer can be reached at 4799-646-4311 for exact info.
Jun 29, 2016 | Ruud Heating & Cooling
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
How do I convert the CFM output to tonnage? Thanks much!
CFM is air flow, a product of fan size and speed and duct size, opening sizes etc.. The tonnage of the unit has no bearing on airflow.
Apr 01, 2015 | Cfm Heating & Cooling
Have serial # B60700097 older heat pump trying to degtermine year and size?
Hi, according to this serial # it is a 1997 heat pump. I would need to know the model to tell you the tonnage on this unit.
Sincerely,
Shastalaker7
A/C, Contractor
Jul 25, 2011 | Amana Heating & Cooling
RUDD Serial RTU 5581F120114360 What is the tonnage or size on this RTU. Which of the numbers indicate the size. Thanks
The serial number will not give you the sizing, but the model number will.
You will need to get the model number to get the info you want.
heatman101
Apr 17, 2011 | Ruud Heating & Cooling
Need to find tonnage of a Luxaire A/c unit serial # ECBM079879...
Get Model number of compressor (all compressors have a tag with a model number on them), and call a dealer who can tell you the tonnage of the compressor which will be the same as the unit.
Note: Write down all the numbers on the compressor to be sure you have the proper info that the dealer will need. Also, you can probably do a 'search' on the computer with the model number of the compressor to find the tonnage.
good luck!
May 03, 2010 | Heating & Cooling
How old is this unit and what is the tonnage
Hi, If you will write down both the model and serial number I can tell you the year it was made and the tonnage.
Thank you,
Shastalaker7
Mar 18, 2010 | Heating & Cooling
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
Based on my serial no and model can you tell me
The unit is a 2 1/2 ton unit. Look at the model number and note the 030 in the sequence of numbers. That tells you the size.
Jan 03, 2010 | Goodman Heating & Cooling
CAN' READ PLATE ON A/C - CAN'T TELL TONNAGE
that comp is a 25k btu depending on the age of the unit it is a 2 ton or 2 1/2
Aug 10, 2008 | Ruud UAKA030 Air Conditioner
Weather King 10AJA3601AH Air Conditioner Logo
190 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
