Question about Whirlpool Duet GHW9150P Front Load Washer
My duets wash cycle stopped
Shortly after starting a wash my machine stopped and is flashing a code DL then F. how do i reset the machine. what does the code indicate what the problem is ?
  • 5,911 Answers
You can attempt to reset the Central Control Unit (CCU) by unplugging the washer for at LEAST 30 minutes. This will often clear momentary glitches with the computer. However, if the error code reappears, you more than likely have a problem with the door latch assembly. "Fdl" is a door latch error which indicates the latch is not locking properly and generally needs to be replaced. The following link explains what to do:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you determine that you need to replace the door latch assembly, parts are available at searspartdirect.com. Just type in your COMPLETE model number and look under the "Door and Latch Parts" heading for item number 7 (part #8181700). I hope this helps you. If you need further assistance, please let me know.
Posted on Nov 10, 2008
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
IT OFTEN (MORE AND MORE LATEY) WILL STOP IN THE MIDDLE OF A WASH CYCLE AND FLASH F 11 AND SOETIMES DL- I CAN'T GET IT TO START AGAIN. IT USE TO HAPPEN ONLY DURING NORMAL WASH CYCLE, BUT MORE RECENTLY, IT...
F11 indicates a problem with the Motherboard that goes into the Computer Control Unit.
Is an expensive part (£150/$200) plus labour so maybe time to just move on......
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I trried to start washer and a code dl came up
dl means there is a problem with the automatic door locking mechanism that engages before the wash cycle is started
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a front load whirlpool Duet washer I stopped the wash cycle to put more clothes in now it just flashes the time left in the cycle but will not restart what can I do?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing a code f dl and won't start the wash cycle? any suggestions?
(800) 659-7026 call this # there was a recall they will fix it free
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool Washing Machines
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
85 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
