Question about Philips 32DV60S 32 in. TV/DVD Combo
TV will not respond (on and off) to remote or controls on the TV itself.I need to constantly shut off the TV for a few hours and wait before plugging it back in.It then works for another 1/2 hour or so and stops responding again.Any clues will be really helpful Thanks Nakul
    Sergeant:
    Champion:
  • 318 Answers
Your tv has some problems, firstly components are heating up on the power supply, later after a power supply is repaired check batteries in the remote. the power supply is a main driver of a tv in terms of switching on & off. thanks
Posted on Mar 20, 2009
SOURCE:
TV stopped responding to remote control
Unplug Tv from power source, wait 10 minutes and replug
Oct 12, 2008 | Toshiba 42HL67 42 in. LCD Television
TV Locked Input Password. Problem is no remote control so cannot unlock. Is there a way reset the TV. None of the buttons on TV are responding as TV is waiting for password.
You can try unplugging it for about an hour to let it reset itself, but I doubt that it will reset the password.
You must have remote control, I would get the original remote to get full functions.
What is the make and model of the TV?
Mar 12, 2011 | Televison & Video
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Sleep timer will not shut off We can not turn it on to shut it off.
unplug for a quite few hours, press and hold power button for 5 full seconds while it is shut off, then wait half hour more and plug back in and it should reset itself.
Jan 22, 2010 | JVC AV-27D203 27" TV
LG LCD TV won't respond to remote controllers
sparrow00, your fix worked for me, and I think I know why. The 1/8" remote input jack on the back of the TV has electrical contacts inside that are probably there to sense the presence of a plug-in remote. When they detect the insertion of this plug they disable the front panel IR (infrared) receiver and the TV only responds to this plugged-in remote and the buttons on the TV itself. After some period of time these contacts get corroded and the circuit is no longer completed between them. The TV now thinks an external remote is plugged in, and it ignores its own front panel IR receiver.
When you plug a 1/8" plug into this remote socket on the back of the TV it wipes away the corrosion. When you remove the plug the internal contacts conduct properly again and the TV responds to its front panel IR receiver. For best results you should plug a 1/8" headphone plug into this remote jack and twist it a few times, then pull it out and repeat several times. Repeat every frew months or whenever the TV acts up.
Thanks for your solution!
Jul 07, 2009 | LG 47LC7DF 47 in. LCD HDTV
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
TV shuts itself off. ON/OFF switch no longer works.
If your sure the switch is broken, you can remove the switch and directly attach the wires and plug and unplug to turn it off and on. But it sound like that if the switch is broken you have a slight connection and with an ajar it will turn off and on by itself. The good thing to do would be to purchase a push button switch at your local electronics store for between $1.25 to $10.00 depending on what one you would like to have.
if it is remote control you could have what they call a sliver on the circut board to that can cause this to make the tv turn off and on. Best way to check this is to take the remote batteries out and see if the tv still turns off and on. If so replace the switch.
May 07, 2009 | JVC Televison & Video
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
Magnavox tv won't respond to remote or panel controls
Could be a bad remote board in the TV...make sure the remote is working by checking it with your cell phone camera
Jan 18, 2018 | Televison & Video
Philips 32DV60S 32 in. TV/DVD Combo Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
