Question about Canon PIXMA MP130 All-In-One InkJet Printer
When i go to print the printer starts but doesnt take the paper
Thge printer starts to take the paper and then stops , thus the printer then thinks that the paper is jammed, this has caused my bottom plate to get dirty and cant clean it without the paper going through. The product is a bout 3-4 yrs old The roller feeding the paper is going round but doesnt take the paper through
  • barry.-karen Nov 17, 2008
    Thanks for the info, looks like it would be cheaper to go out and buy a new printer by the time i have paid for this to be done, thanks again.
  • Canon Master
  • 19,396 Answers
How do you know is the papet feeder, this printer has many sensors.
Being a low cost printer it is not really worth the repair.
Posted on Nov 18, 2008
  • 181 Answers
There is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Posted on Nov 17, 2008
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
Do you think formatting my computer may fix my printer problem??my printer doesnt loads the paper but it just ejects the paper with no print..ive tried to reinstall the printer driver but still...
It sounds more like a cartridge problem. if the printer has been un-used for a while it may simply have a blocked head. If it is going through the motion of printing but nothing is actually printing then it is defiantly a cartridge issue.
This link below will help you rectify this.
If the paper simply feeds in, then feeds out is is a paper sensor issue and I would recommend simply replacing the printer. Fixing it would cost more than the printer is worth.
I hope this Helps Regards GM
Jun 30, 2011 | HP DeskJet 3745 Printer
Printer crashes
Hi Ann,
Check the ribbon cable that comes out of the back of the print carriage for damage / disconnection. They don't normally wear loose, but it is possible.Failing that, the print engine could have failed, which would deliver duff data to the heads, thus printing rubbish onto the page.
Mar 05, 2009 | HP DeskJet 670c InkJet Printer
When trying to print from internet printer starts and stops
Try to reset your system one of two ways. With the printer plugged into your computer unplug from the wall for 30 seconds then plug back in. If that doesnt work then try a hard reset by pressing and holding the Cancel and Left arrow button. Hold down for 30 seconds then plug the system back in and do a test print then tr and print off the internet. If that doesnt work then unistall the Printer software and reinstall the software.
Feb 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
My printer wont load paper so i can print
My Canon started doing the exact same thing. I tried several mods but no luck. Seemed like it would **** hard when starting to print thus mis-aligning the paper. What I found that did worked and solved my problem was putting the printer into 'quiet' mode. In this mode it doesn't **** the paper in as fast and thus doesn't jam. I don't think it has jammed since the change and there's no really noticeable slow down in the output.
Pull up the properties dialog for the printer and go to the maintenance tab.Select 'quiet mode' button and then set it to always use quiet mode. Worked for me. Hope it works for you!
Jan 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Paper Jam
Just check the rollers for debris or any tiny piece of paper. Sometimes using refilled cartridges also can cause this error. Should that not work, you could try a hard reset: unplug printer from pc and mains. wait about 10-15 minutes and while holding down the power button, connect to mains and tho pc. Hopefully that should work.
May 11, 2008 | HP Photosmart C5280 Printer
"Paper Jammed"
Yes I have the same problem :-( I have lots of work to do!!
Apr 13, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Laser printer does not print
Hi there it may just be that the paper tray springs are not pushing the paper higher enough not making contact with the paper detect sensor arm. Or the sensor arm is broken and will need replacing. Check the tray springs also check the sensor arm you will see it if you remove the cassette and look inside there will be a black plastic lever hanging down when you put paper in this lever should go up as the paper acts as a barrier thus telling the machine that there is paper in it.
Thanks J
Jan 28, 2008 | Brother DCP-7020 All-In-One Laser Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
old marine
old marine
