Question about Zanussi Refrigerators
Zanussi zx99/5 freezer working fine but my fridge is too warm
    Scholar:
  • 66 Answers
This may be an airflow problem. These are things to check. Make sure the temp control in the fresh food section for both the freezer and the fresh food is set half way between coldest and warmest temp setting. Over adjusting these settings can cause poor air circulation and make the fresh food section too warm. When openning the freezer, the evaporator fan should be on or start shortly. If the evaporator fan stops working, there will be no circulation to cool the fresh food section and will need to be checked to see if it is bad. If bad it will need to be replaced. The evaporator in the freezer section may be iced over causing poor air flow to the fresh food section. You may need a service tech to check this part. If the evaporator is iced over, stopping air circulation, the button thermostat or defrost element may on the evaporator may be bad and could possibly reqiure a technician to replace it Check the first two things and let me know what you find and how it is doing after reseting the temp control. I will be happy to help you in any way I can..
Posted on Nov 10, 2008
Hi i have a zanussi zi 918\12k fridge freezer. the fridge is warm and the freezer is not working 100%. any ideas?
You more than likely have a bad relay or capacitor. Hopefully it is not the compressor. You may want to consider replacing it if is more than 10-12 years old. The other possibility is there is a leak in the freon.
Feb 13, 2013 | Zanussi ZI918 / 12K Bottom Freezer...
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
I have a zanussi fridge freezer model no zx56/4w. the fridge door was left open for 10 days now fridge is too warm and freezer is icing up
you need to totally defrost the fridge/freezer and start as if it were new and dry.allow 24 hours for the unit to settle to the correct temp.
please leave feed back
Sep 16, 2010 | Zanussi ZX56 / 4 Bottom Freezer...
Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Mar 18, 2009 | Zanussi ZX56 / 4 Bottom Freezer...
Zanussi Z87 problem
my fridege needed defrosting for a couple of days maybe this is the problem with yours.
Sep 22, 2008 | Zanussi FJS1225W Front Load Washer
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi zk73/46ef freezer working fridge is warm
if this is an air blown cabinet defrost it for 48hrs leave the doors open then try it. hope this helps
Feb 09, 2008 | Refrigerators
Fridge is warm, freezer is cold!
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves no working. Good job trouble shooting!
Jan 13, 2007 | Zanussi ZX55 / 4 Bottom Freezer...
Refrigerators Logo
230 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
