Question about Olevia LT42HVi 42 in. LCD Television
Can't get the channels to enter into the channel list
I go to the auto channel add, auto-cable and it goes through all the channels both analog & digital, and always ends up with none. How do allow the tv to auto channel search & watch tv? I have the LCD HDTV model # 226-T11.
  • spartan01 Nov 11, 2008
    Auto channel search runs without picking up any signals. Have checked line and antenna with another tv-no problems. Have let the auto search run for up to 40 min without any channels found.
  • dmccaw500 Nov 24, 2008
    I go to the auto channel add, auto-cable and it goes through all the channels both analog & digital, and always ends up with none. Olevia 747i tv, checked incoming cable is ok but will not pick up channels when scaned.
    Sergeant:
  • 291 Answers
A lot of the " auto channel scan " etc. need a certain signal strength. you could have too meny tvs,equipment or anything connected to the "signal giver" that is sucking the signal strength.Not just turn off ALL connections to signal but disconnect the antenna 'input' to any equipment (sometimes people connect cable wires to radio receivers for stronger & better signals.)
You could have a open circuit to the input of the equipment in trouble.If you know how to get inside (with out killing yourself) connect an antenna directly to the end of the line of the intanna input INSIDE of the TV. if the signal comes in and the tv 'autoscans' and locks channels, then you have a open wire leading into the circuit.
p.s. BE CAREFUL!!, IF YOU don't know how or what you are doing.........DON'T DO DAT !! [that]
Posted on Nov 30, 2008
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
Add channels
Because thats all your TV can see is the feed out the cable box displays which in the US is channel 3. All cable companies encrypt their channels now so you have to have a cable box on every tv
Oct 19, 2014 | Televison & Video
Toshiba 32hl67us -- I am attaching an indoor antenna to receive digital local channels, the tv will only search in analog.. Do I need a converter?
You don't need a converter. You would need one if you had an older Analog TV, to enable it to receive Digital over the air channels.
Check the manual to read about the various configuration sub menus. My TV is a Samsung and when I want to scan for channels, I can select AIR, CABLE, or AUTO. After I select AIR it goes on checking the spectrum, looking for DTVair and Air.
Nov 05, 2013 | Televison & Video
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
I don't have cable. After auto scan for local channels, now 2 local stations are no longer working. I have LG 42LE5400. Do I need to upgrade firmware. Thanks Dj
no you do not need to upgrade the firmware, the channel selection is based on the amount of signal strength it gets, older analog systems would select it as long as there was a slight amount of modulation as for digital it goes by a percentage, if you wish to set these channels then go back under the setup and select manually add channels then you can add any one you whish reguardless of signal strength.
Jun 30, 2011 | LG 42LE5400 42 in. LCD TV
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
Jan 01, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
Olevia LT42HVi 42 in. LCD Television Logo
652 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
