Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Continues to beep the and continues to run
It appears that the spray arm is not engaged and turning.
Problem for a while because dishes were not coming out clean.
I ran an empty cycle with lime away and it would not shut off and water was leaking from under the drawer. The only way to shut it off was at the breaker
Do Not need your help!
Posted on Nov 11, 2008
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Siemans dishwasher model SE55A560GB/42. Upper rotating spray bar not turning but botton spray bar is rotating. Dishes are left with a gritty feel to them.
Check that the arm rotates freely when spun by hand, then check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Apr 13, 2011 | Dishwashers
The spray arms donot move
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Apr 06, 2011 | Dishwashers
The detegent doesn't completely leave the soap dish. the soap door works appropiately --- but the dishes do not come out clean. We have tried detergent pellet, liquid detegent and the basic cascade...
This model relies on the top spray arm to 'wash' the detergent out of the soap dispenser - and that is the problem. Your top spray arm will not be turning properly. Check the angled jet on the very tip of the arms for blockages with food or fruit pips etc - it's this angle only that makes the arms turn.
if blocked, clean out with a pin or wire, and running water - make sure you get every bit out. If not, buy a new spray arm. If the arm is split, you will need a new one.
Other problems may be low water level or a faulty circulation pump - BUT check the spray arms first.
Remember a dishwasher is NOT a garbage disposal unit, so scrape any food particles of plates etc before putting them in the machine. Run a dishwasher cleaner through with no load once in awhile.
Feb 04, 2018 | Crosley Dishwashers
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dish washer problem
check water going into unit. disconnect to make sure there is a strong pressure going through.
check the water valve with a meter if there is continuity the valve is good. if not the valve is bad a no water water will go through. let me know if this helps
Feb 23, 2010 | Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
The arms do not spin and no water is going through them
Switch to a brand name powder detergent like Electrosol or Cascade. Never use ultracheap, generic DW detergent powder in any dishwasher. Run a load with dirty dishes and see the results are.
If cleaning results remain poor open the sump area by removing the lower spray arm and the filter assembly. Remove all debris in and around the sump area. Inspect the impeller down there to make sure it is not broken and that it spins freely. Clean the filter well in the sink. Reassemble. Also, check all spray arm holes for blockage.
Run a load of dishes and check cleaning results. If problems continue, you almost certainly have a failing wash motor and replacement is your next step.
Post here is you would like more assistance. Good Luck!
Apr 11, 2009 | Dishwashers
It runs but nothing gets clean maytag dishwasher
With nothing getting clean, the first thing to do is clean the filter and also underneath it. You will need to remove several screws and the lower spray arm to do the cleaning. Watch out for broken glass! Rinse out the filter as best possible.
Look carefully at the impeller to make sure it spins freely and is not damaged. While you are down there, look for any problems (brakes/damage) with the heating element.
Reassemble the filter and spray arm. Test with a load of dishes.
If problems continue, but the spray arms appear to be spinning well, the problem is most likely a failed heating element. Replacing it should make thing work much better.
Please get back to me with what you find. Good Luck!
Apr 01, 2009 | Maytag MDB7100AWB Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
79 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
