Question about GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
Can not set clock
Can you help set clocks time
  • Anonymous Feb 27, 2009
    Can not set time
  • 3 Answers
All you have to do, is press set and the third time you press it, the dots between the hours and minutes will blink, then use the skip and back arrows to set the time, then press set once again when you are done.
Posted on Jan 11, 2009
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
How do I set time on the Brookstone Ipod cube radio? Thank you
Simply HOLD down the "CLOCK SET" button for ~3 secs and the time will flash... Rotate the dial around the SNOOZE button to the hour you want; click the "CLOCK SET" button again for the minutes and rotate the dial again... Hit the "CLOCK SET" button one last time and you're done! Need help with solving real problems? Contact me at Help@OPRIMAX.com
Jul 23, 2011 | Brookstone (467522) Clock Radio
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    Cannot set the time
    1. Slide the Lock/Wake/Clock switch to the Clock position to enter the clock setting mode.
    2. Press REV or FWD to set the time. Press and hold to decrease or increase the time value quickly. The ":" flashes on the display in clock setting mode.
    3. Slide the switch back to the Lock position.
    Hope this helps! If it did, feel free to rate me. Thanks for using FixYa.
    Mar 13, 2011 | RCA RPC100 Clock Radio
    Hi,Ive been trying to set my icf-cd2000 clock radio,I downloaded info,It is so small I cant read it.(ive tried to make it larger on photo copier) but it only blurs ,can I buy a manual please,Or do you have...
    Setting the Local Time
    1. Press WORLD/LOCAL to display "LOCAL".
    2. Hold downl CLOCK until you hear a beep.
    3. Press TUNE/SCAN TIME SET + or - to set the hour.
    4. Press CLOCK to enter the hour.
    5. Press TUNE/SCAN TIME SET + or - to set the minute, and then press CLOCK. Two beeps sound to confirm the setting.
    Setting the WORLD Time
    1. Press WORLD/LOCAL to display "WORLD".
    3. Press TUNE/SCAN TIME SET + or - to set the desired hour and press CLOCK. Two beeps sound to confirm the setting.
    If you need any more help, feel free to ask.
    Mar 08, 2011 | Sony ICF-CD2000 Clock Radio
    I have the alarm clock and the time won't stop flashing, we can't put the right time. What can we do, please help, it's really anoying!
    1. Slide the Lock/Wake/Clock switch to the far right (the Clock position) to enter the clock setting mode.
    Jan 29, 2011 | RCA RP5430 Clock Radio
    Westinghouse microwave WST3502..... Problem:
    Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
    Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
    Clock Problem
    The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
    If you don't have the manual, the usual sequenceof clock setting is one of these:
    Clock > digits> Clock
    Clock > digits> Start
    Clear > Clock > digits> Clock
    Clear > Clock > digits> Start
    Clock > Clear > digits> Clock
    Clock > Clear > digits> Start
    Otherwise, it may be hard to help beyond this, since it;s been a long time since Toshiba made microwaves.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Mar 17, 2008 | Microwave Ovens
    Cant set time
    Rondart
    Rank:nonexpert_s.gif Apprentice
    Rating: 0%, 0 votes
    On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory5.gif.
    Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
    The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
    The third is just the brightness.
    Now, to set the time itself:
    1 - Turn the clock face back up to where you can see it.
    2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
    Good Luck!
    Mar 10, 2008 | RCA RP5420 Clock Radio
    Setting the time on Sharp microovens.
    Normally it's
    Clock > time numbers > Clock
    or
    Clock > time numbers > Start
    Sometimes it's
    Clock > (1 or 2) > time numbers > Clock
    or
    Clock > (1 or 2) > time numbers > Start
    If this doesn't work, please reply back with your model number.
    Mar 08, 2008 | Microwave Ovens
    GE 74801 DUAL ALARM CLOCK RADIO .9" LCD Logo
    247 people viewed this question
    Top GE Audio Players & Recorders Experts
    Greg Cann
    Greg Cann
    Carlos L. Burgos
    Carlos L. Burgos
    SHARCNET-USA
    SHARCNET-USA
    Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
