Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Bought linksy modem because of provider now wireless dont work
It worked for about two weeks after then they stopped. provider told me to plug it straight to the modem and it works like that but not if it is plugged to the wireless router
  • bass7368 Feb 10, 2009
    I've had this now for about 4 years and up until a couple of days ago its worked fine. I've connected it to the laptop via a cable and it works but as soon as try to use wirelessly I lose connection.
    Scholar:
  • 49 Answers
Hi Guys,
What needs to be defined first is the reason as to why it had stopped working. Before a suggestion is made, we first need to find out what the model number of your router is (there are many version of the linksys wrt54g router). Once that is defined i suggest you reset your router by doing the instructions as per this web page (cop and paste in your browser): http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Once you have done that, the router should be set to factory default leaving you with a fresh clean slate. You can then proceed to configure the router for wireless security (if you need it) by following the steps here: http://technicallyeasy.net/2007/09/securing-linksys-wrt54g-wireless-router/
The instructions on these pages should help, however, if you face any uncertainties, please do feel free to get back to me and i shall attempt to cover whatever i can do to help the both of you out. Thank you.
Regards,
Technomancer.
Posted on Nov 12, 2008
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
Router works well most of the time....then for past two weeks it won't rout to other 2 PC and will not allow me to access modem. If I disconnect and plug in direct to PC modem works. Called high speed...
I have had similar problems in the past with 3 different brands of wireless routers, including the linksys Wireles-G router. In all cases, it was the same scenario, worked fine for a year or so, and then started giving inconsistent intermittent connectivity problems. Resetting, recycling etc. etc. would work for a while and eventually it would become unusable, and I would end up replacing. I went from a D-Link wireless router, to a Belkini, to a Linksys, and now use the Apple airport wireless, which I have also recently replaced with another Apple airport wireless. So unfortunately, I can't tell you if it's me doing something to kill them or if they are just short life expectancy for wireless routers, but the only fix I have experienced is replacing the router. Good luck...
Aug 30, 2010 | Linksys Wireless-G WRT54G Router
Hooking up a Linksys dual range router to a 2 Wire cable modem
ok once your internet is resolved you shouldnt need to have any computer hard wired to the router but it should go like this cable from your wall to the modem, then cable from modem to the router, after that you can go wireless all the way just make sure that its all secure and encrypted dont want the next door neighbor stealin your internet
Feb 25, 2009 | Linksys Ultra RangePlus Wireless Routr...
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Linksys Wireless-G WRT54G Router
LInksys wireless router stopped working
Who is your internet service provider and what is the model no. and brand of your modem?
Jun 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Need tech advice
No and why doesn't your internet provider... provide a cable modem?? Did you just ask them to enable broadband internet service? So now you'll have to provide your own cable modem.
If what you say is correct you need a cable modem like a motorola surfboard from BestBuy.... then the cable modem plugs into your Linksys router and your PC's plug into the linksys router also.
http://www.bestbuy.com/site/olspage.jsp?skuId=8229044&st=motorola+surfboard&lp=1&type=product&cp=1&id=1168043113583
May 05, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Connection drop-outs
Is your laptop wireless adapter a compatable brand. It doesn't necessarily mean the router is bad, you may even be getting RADIO interference from a cordlees or a cell phone in it's path. Do you have the capability to plug a cat-5 cable directly into your laptop from the router when you lose wireless? Check the wireless channels and see about changing the channel on your cordless phone too. May not work, just a hunch.
Good Luck
Mar 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
