Coleman furnace fan keeps turning off and on every 10 seconds...
Coleman Furnace Model 7680B Series 856
Sometimes this furnace runs perfectly, but about once a day the fan seems to get stuck or something and it keeps going on and off every 5 to 10 seconds---when it does this there is no fire in the box, just the pilot light is on. I have to turn ithe furnace off for about 30 minutes and then it will run okay for about six hours or until it does it again. Any ideas? It has 3 limit switches that I am aware of.
  • 1 more comment
  • Satellite2 Nov 20, 2008
    Mine does the same thing after every heat cycle. About 15 seconds after the heat shutd off, the fan starts and goes off/on off/on maybe 29 times before shutting off.
  • seafroggy22 Dec 17, 2008
    When heater is turned on, the fan periodically starts going on and off, on and off, on and off.....until it starts driving me a bit crazy. Then I go to the thermostat and turn if off (push lever all the way to the left) and it still takes several minutes to stop going on and off, on and off, on and off.......The gas regulator was replaced last year and okayed by the gas company. He also checked the thermostat and said it was working fine.
  • deadcandance Mar 16, 2009
    Mine has the same problem, is anyone listening? Help
Clean your heat/flame sensor with sand paper or steal wool. If the sensor is dirty, it won't detect the heat from the flame and it shuts the gas off. Clean the soot and junk off the sensor and it should work fine. I have to clean mine every year. After spending hundreds of $$ every yr on tech calls..I figured out the problem and in 30 sec I'm up and running again.
Posted on Jan 03, 2011
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
4322 coleman furnace
Check electrical xxxxxxxxxxxxxxxxxxxxxx
May 23, 2014 | Coleman Heating & Cooling
I have a coleman model 7680B series 856 with a pilot light that won't stay lit
You need a themocouple, it's a cheap $10.00 part you can get at any hardware store, you have a standing pilot light furnace like mine, if your handy and safe you can put one in easy, youtube is loaded with videos on how to do it. These other answers are wrong for your unit.
Oct 26, 2011 | Coleman Heating & Cooling
Coleman gas furnace model #8665d766,..the burner cycles great,...but fan motor will sometimes continue to run,..if you hit it on the front side lightly,..it shuts off...?
Hello, this sounds like it may be a problem with the relay on the integrated control board. it sticks occassionally and therefore the fan will keep running, when you hit the front side it causes the relay to open and thus the motor turns off. only option is to replace the control board as the relay cannot be replaced byitself.
May 15, 2011 | Coleman Heating & Cooling
Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Jan 19, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
2,080 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
