Question about Lexmark Optra S 2450 Laser Printer
Optra 2450 error 241
Optra 2450 tray 1 error 241
    President:
  • Lexmark Master
  • 1,314 Answers
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Posted on Nov 10, 2008
Paper tray on optra n is not coming up and message says load paper
Check the paper guides on the paper tray, check if they are set to the correct paper size.
Dec 13, 2012 | Lexmark Optra S 1855 Laser Printer
I keep getting a paper jam error with my Optra S 1855 printer, but there is no paper jam. This error interchanges with a message asking me to Change the paer in tray 1 to letter size, but it is already...
Open the tray and make sure the green paper lever is set to letter mark, both at the bottom of the paper and the one on the side. And yes, if you haven't used it for 3 years, you should clean the dust that settled inside your printer over time.
Dec 06, 2010 | Lexmark Optra S 1855 Laser Printer
Get the error message change tray to plain letter
Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: http://bit.ly/c4AO17 . You can move the paper tray guide back and forth and setting it to the correct size.
Apr 08, 2010 | Lexmark Optra T610 Laser Printer
I have a optras1855 printer and a message keeps coming up 241 paper jam check tray 1. the problem is there is no paper jam. i know this because i have another machine the same model and that does the same...
I'll bet that if you put a mark on the top sheet of paper in tray one and then send a print job or run a self test you will see that the paper stays in tray one. I suspect that you have a paper pick problem.
Worn or slick rollers can be one source or a weak tray supports. Also, take the paper out of tray one and fan the paper to break any static that may cause the paper to stick together.
Don
Dec 17, 2009 | Lexmark Optra S 1855 Laser Printer
Lexmark Optra T610 keeps saying "change tray one to plain paper"
3 possibilities
1) the paper size sensor in the tray(those teeth on the size of the tray) is broken
2) The sliding paper guide is not pointing precisely at Letter
3) Your paper type is set to something other than Plain Paper.
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
I'm currently experiencing a paper jam error 242 tray 2 on the Lexmark Optra 614 Laser Printer. Any clues?
try changing feed rollers in tray. To test or temporary fix remove the rubber tires and flip them inside out, then reinstall.
Dec 24, 2008 | Lexmark Optra T614 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
LEXMARK OPTRA R+ SAYS LOAD PAPER 28
Try loading paper in both trays. Tray '2' is supposed to be the bottom tray. It is a much larger tray than the top tray which sits underneath the duplexer.
IBM 4039 drivers also work for this model.
Apr 30, 2008 | Lexmark Optra R+ Laser Printer
Lexmark Optra S 2450 Laser Printer Logo
634 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
