Question about Panasonic CT-32SX31 32" TV
Can't change our Panasonic TV channel to watch DVD input
We have an older Panasonic 32" television (approximately 12 years old). It works fine, however, we no longer have the original remote control. So, we purchased a universal remote control that controls nearly all functions EXCEPT changing the TV to the "video/aux" channel 2 or 3 so that we can watch DVD input.
Is there a way to do this manually with the TV controls - or some trick to do it with the TV controls (and not using the remote)??
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
TV Stuck on Video
hit input button u dont have orgibnal remote for tv so go to the tv hit ch down button to u see it chage the inputs to video 2 3 whatever your cable is on dvd ect ok
Jan 27, 2008 | Televison & Video
Picture is washed out and looks green. The TV is an lcd Flat 32" poloriod model. It is four years old. This just happened this week it's not been moved or anthing. It shows no change from channel to...
The tv Tuner board that recieving the incomming tv signal broscast is defective.Tries Websites like, to buy a refurbish Tuner board for the replacement.
May 06, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
Jan 31, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Can I change input mode manually?
Try channel button to 1-2-3--99-98-1-2-3 up & down it should come between 0 & 1
Jan 21, 2010 | Sylvania SRT2232S 32" TV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Can''t get aux channel to watch dvd player
do you have an input, tv/video, source or a/v button on your tv set if you do, press that, and it will change it
Apr 04, 2009 | Sanyo DP32746 32 in. LCD Television
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic CT-32SX31 32" TV Logo
1,396 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
