Question about JBL PSW-D110 Speaker
JBL PSW D100 blown fuse
When the unit is pugged in the indication light is not lit, could it be a blown fuse?
    Brigadier General:
  • 8,546 Answers
Not likely. There are no fuses according to the instructions I found for the D-110. I assume they're about the same.
Try it with nothing attached anywhere except the power cord. No light immediately = dead.
Posted on Nov 30, 2009
What type a fuse do I use for my Psw 125 power sub
Is this a Polk PSW 125? I'd contact Polk customer service.
Here is the manual http://www.polkaudio.com/Media/POLK/Product%20Manuals/PSW110_125_MN.pdf
There is some discussion here http://forum.polkaudio.com/discussion/77264/psw125-blown-fuse
A blown fuse indicates something wrong. I'd contact Polk.
Nov 17, 2015 | Audio Players & Recorders
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
What is the size of the JBL PSW-D110 fuse?
The fuse is a 250volt 1.25 amp slow blo.
First thing I would do is check C6 to see if it is bulge or blown - regardless replace it with a 10ufd 100volt Non-polarity capacitor. If the fuse blows again unplug the blue wires from the transformer and plug in unit to an outlet. If fuse does not blow then problem is on PC board. I have a service manual for this item. Probable causes on PC board are Filter Caps, Bridge rectifier (DBA), Amplifier module, or fragments of C6 even causing shorts on board if it had blown.
I have bought C6 from MCM Electronics for under .50 cents but you have to put shrink tube on one lead and bend it back along the body and solder both leads in the board.
Good luck
Jun 24, 2011 | JBL PSW-D110 Speaker
I have moved from place to place...and all the sudden I can't get my jbl psw-d112 woofer to work....i took it apart and think maybe the blue and black wire came off the actually woofer...i need to know...
Are you not sure the wires came off? If they're off, reconnect them and get back to us. Absolute polarity doesn't matter. You can always reverse the phasing with the external Phase control.
When you say you replaced the fuse, was that a wild guess or was the fuse really blown?
Jun 20, 2010 | JBL PSW-D112 Speaker
Power not working
If it is fused check to see if the fuse is blown... Start with power and work you way down from there.
Power to the sub.
Signal to the sub
Cabling to sub
Check the speaker itself to see if it is good.
john
Aug 16, 2008 | JBL PSW-D112 Speaker
JBL PSW-D112 Speaker fuse blow immediately after replaced
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
Jun 27, 2008 | JBL PSW-D112 Speaker
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
Keeps blowing fuse need parts?
You can email me : Franknguyen57@hotmail.com I will have part for you. Thanks
Aug 16, 2007 | JBL PSW D115 Speaker
JBL PSW-D110 Speaker Logo
336 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
