Question about ECM Giotto Espresso Machine
Giotto pressure valve constantly on
My Giotto machine does not seem to to control the pressure anymore. When it gets to 1.5 bar as it is set, I can still hear the pressure escaping. Any comments/solutions?
    Sergeant:
  • ECM Expert
  • 223 Answers
You must have an internal leak and your machine will need to be serviced. If you can remove the top of the machine maybe you can see where the leak is coming from and may be able to repair the machine yourself.
Cerini Coffee
Espresso machine service and Sales
www.CeriniCoffee.com
Posted on Nov 18, 2008
I turn the ECM Giotto on, the light comes on but the pump does not activate and no heat. 2 hours later it all works fine.
Try this open the steam valve when you turn the machine on, leave the valve open until it starts to hiss with steam, then turn off valve. If that works then the vent valve is sticking and needs to be replaced.
Oct 12, 2011 | ECM Giotto Espresso Machine
Air pressure excessive
that's a valve that's in line with the internal plumbing..that's all that restricts that pressure, which can build quite high.
can you provide the exact model number, please?
Mar 02, 2008 | ECM Giotto Espresso Machine
Ecm Giotto
Have you checked the Thermostat on the unit in the tank if it is stuck it will cause the tank to over heat and pop off the steam valve?? there should be some resettable overheat protectors as well. Has the preassure relief valve been replaced as well??
Feb 14, 2008 | ECM Giotto Espresso Machine
I have a Giotto ECM esspresso machine. it is approximately 3 yrs old. recently when i turn the machine on, it starts heating up, but it doesn't create any pressure. any suggestions how to fix this problem.
Hi
1 solution is your vacuum breaker valve is sticking. Try opening the steam valve and see if you can start to heat again. If it does just, replace your vacuum breaker valve.
Sep 20, 2010 | ECM Giotto Espresso Machine
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
ECM Giotto
sound like it need to taken apart for a good cleaning. Hard water will cause build up ..your user manual should tell you how. i have the manual. It says Hard water will cause that problem.here is the link for the manual.http://www.espressotec.com/store/pc/catalog/pdf1/ec1300_ecm_giotto_manual.pdf
Jan 02, 2008 | ECM Giotto Espresso Machine
Hey! My ECM Giotto is building up too much pressure. 2+ bars. I tried resetting it but no lick. New thermostat?
The pressostat can be full of scale. You can remove it when the machine is cold descale it and also use a litle lubricate so the part can move more easily. You migh need a new mebrane since it might have be damage but if you dong have you can cut a plastic the same round shape of the mebrane and put the both back again so that no steam will escape from the mabrane.
Feb 13, 2010 | ECM Giotto Espresso Machine
Boiler bar gauge has no pressure
please check to see if its not sticking refill with water
May 04, 2009 | ECM Giotto Espresso Machine
Wet grounds
What you see is condensed stem comming out and no water. The pump is not sucking from the tank as ther is an air bubble in suction line. Still want coffe and don't want to clean your machine??? Flick up the lever with no group in place. Steam comes first then nothing. Pump is running and - voila - water comes as air bubble is gone. (Specially the first cup , never the following ones.) Now put back the group and brew your espresso. The machine is full of scale and neds total clean - by hand./// Olev
Jun 13, 2008 | ECM Giotto Espresso Machine
Air pressure problem
I am having a similar problem.  Doesn't happen all the time, just sometimes.  My research has led me to believe it might be the vacuum breaker valve.  I am going to order a new one here:
https://www.chriscoffee.com/products/home/parts/vbreakervalve
I'll replace mine & post if it fixes it.
Good Luck
Sep 02, 2007 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
227 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
