Question about Koss KS3102 System
Very low volume.
My KS3102 is having two problems. First, when cranked all the way the volume is barely audible. Next, on the speaker status display the icon is telling me my surround [rear] speakers are not working or not hooked up, I'm not sure. The speakers are hooked up. I don't have the remote yet, that arrives this afternoon.. Thanks, Wally
  • Anonymous Jan 04, 2009
    low sound 50 or better to hear
    Sergeant:
    Champion:
  • 201 Answers
If you get the remote look under menu see sound settings, otherwise somewhere under menu should be a reset option do try that
Posted on Dec 07, 2008
Sound is very low
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 14, 2012 | Asrock 775Dual-880 Pro Motherboard
Samsung ht q-20 quiet at full volume after kids were playing with it. All speakers work just barely audible at max volume. Help!!!
First, check to make sure all wires are plugged into the correct location. If the problem persists try changing the amp or play source that you are using to see if it is a problem with that. Their is sometimes a secondary volume knob on the speakers as well. Hopefully this helps.
Feb 15, 2012 | Samsung Audio Players & Recorders
Amplifier powers up. low humming, and music is barely heard at full volume.
The main amplifer ICs have taken a dump. Time to go shopping!
Nov 15, 2011 | Audio Players & Recorders
Just installed new front (Pioneer TS G4643R) and rear (Kicker KS4100) speakers in my 1989 S-10. The left front and rear speakers work great but the right ones are not so good. At low volume they both have...
It sounds to me like your wiring is having problems. An easy way to tell would be to switch your speakers around. Take the ones on the left that you know work, and place them on the right side. If you have the same problem, then that tells you the wiring is having problems. Another problem could be that the speakers are wired out of phase. What that means is that the positive of the speaker is connected to the negative of the radio or amp, and that the negative is wired to the positive of the amp. Do you have an external amp? Try switching them around, and let me know how that works for you.
Apr 11, 2011 | Kicker KS4100 4 x 10 Coaxial Car Speaker
Sound on the speaker is very low voices are barely audible. have tried all eq settings but sound remains low please help
Look through your receiver's DSP sound settings. When you locate the volume control for the center channel, adjust it to be in balance with the music and sound FX. Often, I just forget about the DSP and run the sound in stereo with subwoofer. Helps to minimize the different audio mixes between different TV STATIONS AND DVDs.
Oct 06, 2010 | Cerwin Vega E-76C Center Speaker
Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Mar 21, 2010 | HP Pavilion dv6000z Notebook
Just shuts down, then wait about 5 min. then turn off then on and it's OK -Totally random. Does not appear to be a heat problem
These units have a protection device that will trip an internal breaker and shut off to prevent damage. This feature will function normally if: 1. the volume is too loud. 2. You have a stray wire touching either metal on the unit or the wire from an adjacent speaker. Check all of your speaker wire connections. Also, it can't hurt to make sure that the speakers are all properly phased (+ and - connections are consistent on all speakers.)
As an afterthought, I've seen this happen too if the wires are too long or if there have been multiple splices. When the amp cant push the speaker and is overworking itself, the breaker will turn off.
Apr 19, 2009 | Koss KS3102 System
Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Apr 10, 2008 | Bose Companion 3 Computer Speakers
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Channel 2 volume is very low
You can check if channel 2 is blown by switching around your RCA plugs. If you are using the speaker wires as high power inputs you can change them. I.E. swap the left channel with the right one. I assume you checked the gain control on the amp. If channel 2 works with channel 3's inputs then its your head unit or the wiring. If you are lazy take the amp to a car audio store and ask them to bench test it for you. Hack
Jul 13, 2007 | Nakamichi PA-504 Car Audio Amplifier
Koss KS3102 System Logo
132 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steve K
Rick
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
