Question about Linksys Wireless-G WRT54GS Router (e125894)
Connecting issues with wireless mode on WRT54G2
HI have configured my router WRT54G2 with security mode as "WEP" and Trasnmit key as = "1".
Pass phrase is 10 bits.
Nowon the laptop side, "N/w Authentication" is open, "Data Encryption" is"WEP". I also entered the Network Key as it was entered in thr router.
Nowon connecting to the wireless network, It tries connecting to therouter, but then after some time I see the status as "Limited or noconnectivity".
Any idea where i am going wrong.
  • 1 more comment
  • dhuru9 Nov 10, 2008
    BTW.. Connection works fine using the Ethernet port on the same laptop
  • dhuru9 Nov 11, 2008
    thanks for your reply
    The N/W authentication support on the laptop are as below
    . Open
    : Shared
    . 802.1x
    . WPA-Enterprise
    . WPA-Personal
    . CCKM
    I used the authentication as "Shared" and entered the key.
    Also used Open
    Still it does not connect to the router.
    The UI for my router can be seen from the following link
    http://ui.linksys.com/files/WRT54G2/1.0....
    I also perfomed the steps you told, but it still does not work.
    Firmware version on the router is already latest to 1.0.01
  • msdesi Nov 11, 2008
    I was having link problems last night and now I am unable to connect. I am kicked out of my secure network.
    Scholar:
  • 132 Answers
You may set Wireless security of the router to WPA Personal instead. Since it is the supported wireless security of your laptop. If the router is set to WEP then WEP must be set in the laptop as well. But if WEP is not supported by the laptop anymore, then might as well, set WPA Personal to the router.
Hope this helps!
Posted on Nov 12, 2008
    Scholar:
  • 132 Answers
  1. Try to disable WEP in the router and check if the wireless computer will be able to connect to the router and Internet.
  2. Then enable WEP again. If the same problem happens, upgrade the firmware of your router.
  3. Click on the link for the lastest firmware available for your router.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1175242897803&pagename=Linksys%2FCommon%2FVisitorWrapper&displaypage=nodata#versiondetail
Hope this helps!
Posted on Nov 10, 2008
I cannot access my wep hex key how can i locate
The WEP key is an encryption key that secures your wireless router from unauthorized access. WEP is an old encryption method for a later and stronger encryption use WPA or better still WPA2.
Connect a LAN cable from the Linksys to the LAN port on yourcomputer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 10, 2011 | Linksys WRT54G2 Wireless Router
I have a linksys WRT54G2 wirless router and i need to know, what my WEP KEY PASSWORD IS i never knew what my WEP KEY was are you able to help with this issues. thank Diana Kelly
http://192.168.1.1
Sep 10, 2011 | Computers & Internet
I got a SONY PSP and it said that it scans through my Linksys WRT54G2 wireless router, it also says i need a a WEP key or a WPA key to make it work. what is the WEP or WPA key?
WEp key is your wireless security key
You can open the router page with ip address 192.168.1.1
enter user name = leave blank
Password =ADMIN
Enter the router setup page
Click the wireless tab.
Go to wireless security tab and below the wireless type there will be security key.
That is your key.
Sep 04, 2011 | Linksys WRT54G2 Wireless Router
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Where to find security code on a router
The security key is the WEP or WPA or WPA2 encryption key that is configured in the router's wireless settings. You need to connect a LAN cable from your computer to your Linksys, open a browser and enter the router's configuration URL then login to the router then go to the wireless settings for this info or to change the wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Dec 05, 2010 | Linksys WRT54G2 Wireless Router
How do I obtain my own WEP Key?
Hi Friend,
Please follow the steps:
1.Open router page(192.168.0.1)
2.Enter the username and password.
3.Click Wireless settings.
If you have configure the password you can see it in this section or else you can configure the passwword as mentioned:
Name(SSID)-As per your choice
Region-As per your location
Channel-1
Mode-you can select g only (if u have a G wireless adapter)
Security options
WEP
Security Encryption
Authentication-Automatic
Encryption-64
Security Key
Key1-Type a 10 digit or 10 letters password(like your telephone number)
Click Apply and turn off the router for 30 seconds.
You have a secured network now.
Regards
Chiranjeet
May 23, 2010 | NetGear WGR614 Wireless Router
I have internet with time warner so have linksys router wireless'but when a try to connect to other computer don,t work
First, check to make sure that you can get Internet through a wired connection, if you can't then wireless won't work either. Second, if you can, then try connecting to the wireless without using WEP or any security. You can turn this off by going to 192.168.1.1 in your web browser while wired to the router from your PC and go under wireless security. If you can connect from an unsecured access point then set up a WEP key with a pass-phrase and when you are asked for the pass-phrase from the PC use the the hex key 1 that is generated by the router instead of the pass-phrase. You should have no problem connecting. Thye wizard that comes on the configuration CD will not set up your wireless correctly, you really have to configure the system using the IP.
Oct 01, 2009 | Linksys Wireless-G Broadband Router
Another problem... wireless router Allied Telesyn wa1104g
can you connect without the security???
if so. configure the router with minimum security. if that is good than go up.
you need to clean out the setting on the laptop first.
delete all of the network that the laptop can find. do a fresh search. click on the router you want ot connect. if you setup the WEP. it will ask for a pass key type in the key exactly as you have on the router (case senstive).
let me know if you need addtional info.
Nov 07, 2008 | Computers & Internet
How do I find out my wep key
Looks like you will have to login to the router from the other computer to find the key.
Usually, the address to the router admin screens is one of the following:
192.168.0.1 Linksys
192.168.1.1 NetGear
192.168.10.100 Motorola
Generally 192.168.1.1 will work for most.
Default Login:
Login = admin
Password = password (default - if this doesn't work, then you will need to find it or initialize the router)
Go to the WEP security Screen
NetGear EXAMPLE:
Security Encryption (WEP)
Authentication Type *Automatic*
Encryption Strength *64bit* (64 bit is sufficient - the network overhead is less than 128 bit)
Security Encryption (WEP) Key (The active key below is marked with *)
Passphrase *Blank*
Key 1 abcdabcdab (64 bit examples = 10 hex digits 128 bit will be longer string)
Key 2 dcbadcbadc
Key 3 123456789a
Key 4 *Blank*
Click logout when finished
LinkSys Example:
Wireless Network Menu
Wireless Network Mode Mixed
Wireless Network Name (SSID) MyWireless
Wireless Channel 7 - 2.442 GHZ
Wireless SSID Broadcast Enable
Wireless Security
Security Mode WEP
Default Transmit Key 1 (This is the active key)
WEP Encryption 64 bits (or 128 bits)
Passphrase
Key 1 abcdabcdab
Key 2 dcbadcbadc
Key 3 123456789a
Key 4
There is no logout for the LinkSys. Just disconnect
Oct 27, 2008 | Computers & Internet
Linksys Wireless-G WRT54GS Router (e125894) Logo
140 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
