DTV connection I have a 48'' Mitsubishi tv, that says it is HDTV INTEGRATED. I am trying to connect an over the air antenna to receive local channels broadcasting in hd, but I am not having any luck. I connect my antenna line to the DTV PORT on back of tv then run scan looking for channels, but it says none found.
Have you tried http://www.antennaweb.org/aw/Address.aspx? This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
Posted on Dec 01, 2008
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
Sep 11, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Tv wont pick up channels
Have you been into scanning settings and set to DTV , it seems like you are either on ATV or have a bad Antenna connection. If signal is weak from your Antenna you can add a booster in the section between your wall socket and the TV. You cannot use Satellite dish connections to receive either ATV or DTV signals without a set top box ...
Dec 05, 2017 | Coby TF-TV1901 19 in. LCD Television
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Does a CT-27614A need a digital converter for antenna?
I hope this soultion is helpful.
Feb 12, 2009 | Panasonic Televison & Video
Want to use my old dish set top as dtv tuner
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Nov 16, 2008 | DISH Network 301 DTV Receiver
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Unable to detect some local DTV channels
chec kthe settings
they might be at fault
Sep 06, 2008 | Computers & Internet
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
