Question about Apple iPod mini M9160LL/A MP3 Player
Ipod Mini stopped working
My Ipod Mini (after 1 yr use) - appears to be out of commission. All of a sudden it stopped working. No signs of life when i attempt to recharge it. I have not dropped it, etc. Had been in my car for a while (i.e. subject to temperature changes). thanks
  • Anonymous May 08, 2008
    my ipod states that i should go to www.apple.com/support/ipod. it happened when my ipod was left in the car always playing.
Reset your iPod. I just tried it and it worked! YAY!
http://www.werty.net/2004/06/reset-ipod.html
Posted on Aug 28, 2008
  • 4 Answers
Does it work while in a cradle or connected to the pc? If so, the battery is probably toast. I don't know if it is worth the investment to you to just get a new battery or a new iPod.
Posted on Nov 20, 2007
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
How do I reset an ipod mini 4G?
To reset iPod mini:
1. Toggle the Hold switch on and off (set it to Hold, then turn it off again).
2. Press and hold the Select and Menu buttons for at least 6 seconds, until the Apple logo appears.
Download Apple iPod Mini Manual
Aug 21, 2014 | Apple Mini IPod
My mini ipod freezing, showing charger sign i could not turn it to menu
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
No audio after replacing ipod mini battery
You might just need new headphones..
Only one of my earbuds work on my earphone because they have been used a lot.
Jan 01, 2009 | Apple iPod mini 2nd generation MP3 Player
IPOD mini won't play purchased music unless 100% charged
I've called Apple support on this before. They told me to make sure that the Ipod is set for Manually manage music in the Ipod settings of ITunes. You should restore all software in your IPod to factory settings before doing this.
Jul 14, 2008 | Apple iPod mini M9160LL/A MP3 Player
Ipod mini screen freezing
How to manually reset a frozen iPod mini:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, which takes about 6 to 8 seconds.
http://docs.info.apple.com/article.html?artnum=61705
Feb 26, 2008 | Apple iPod mini M9160LL/A MP3 Player
Apple ipod mini
do a reset...
hold the centre button and the menu button down similtaniously and hold them down until the apple logo appears on the screen then try it.
Nov 12, 2007 | Apple iPod MP3 Player
Broken ipod mini keypad
Try resetting your ipod as follows.
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. (use one finger on each key)
You may need to repeat this process but it should restore the functions of the click wheel.
Nov 11, 2007 | Apple iPod mini M9160LL/A MP3 Player
Mini ipod freezing showing charger sign
restart your pc press del key in your keyboard,
go to setup usb settings disable usb 2.0 setting
Sep 15, 2007 | Apple iPod mini M9160LL/A MP3 Player
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
187 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Mohamed Ismail
Mohamed Ismail
woodzowl307
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
