I'm not sure about my problem - Computers & Internet
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    I'm not sure how to help you with the problem you're unsure about.
  • 42 Answers
Hey buddy how can i help u if don't know what u need
Posted on Nov 12, 2008
What features should I look for when buying a bullet proof vest?
When buying a bullet proof vest, you should follow these steps:
Make sure it is comfortable and allows great mobility
Make sure it provides you with maximum protection
Make sure the level of protection meets your needs
Make sure you buy it from a decent company that you can trust
Make sure the vest is adjustable
Feb 04, 2013 | Work Safety
Skipped bottom stitches
try changing the needle
make sure the bobbin is inserted correctly
make sure the bobbin is not warped
make sure the bobbin is turned the right way in the bobbin case
make sure the top tension is adjusted correctly
make sure the top and bobbin thread is the same
Feb 01, 2013 | Brother XL-5130 Mechanical Sewing Machine
Distorted audio
Check the connections to the speaker(s) and make sure the connections are clean and sound first. If you are running in bridge mode, make sure the connections are correct- someone may have unplugged them.. Check to make sure input sensitivity is correct, and make sure mode is correct for your setup. and press rest button as a last resort.
Check external connections to make sure nothing is shorting, and also check to make sure any inputs are not shorted or broken, and any muting or monitor functions are switched off on the mixer. Also check any network connections to make sure they have not pulled apart in the keystone.
Dec 17, 2012 | Crown 160MA 60 WATT AMPLIFIER WITH...
Headset problem
the headset should have 2 plugs one green one red they usually plug into the back of the computer with the speaker plug in the middle you could alternate these also make sure the microphone settings are correct
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Feb 14, 2012 | Computers & Internet
The Audio on my dvd player is not working, every else seems fine
Hello
[1] Make sure the audio jacks are securely
connected
[2] Make sure the audio connector is not
damaged
[3] Make sure the volume is turned up
[4] Make sure you have set the player's audio
settings correctly
[5] Make sure you have entered the correct AV
input for your TV
[6] Make sure the audio is not set to mute
OK.
May 15, 2011 | RCA DRC628 Portable DVD Player
It's not working!
Make sure all the cords (power and data) from the base unit all securely plugged in.
Make sure you have pressed the CONNECT button on the base and the mouse to initiate the connection.
Make sure the mouse is not too far away from the base when it is being used.
Make sure the LED underneath the mouse is clean of dust or debris.
Make sure the light path bewtween the mouse and the base is not blocked by any object.
Make sure the batteries are fully charged, replace with new ones if necessary.
Make sure there are no other wireless mice in the immediate area which may cause interference.
If all this still doesn't work, try reinstaling the driver and restarting the computer after it is installed.
Good luck.
Mar 06, 2011 | Logitech Cordless Mouse
Mi estereo no power
comprobar su fusible estéreo
Nov 12, 2009 | 2006 Nissan Altima
Conection error
That could be a number of things.
Make sure there's a signal,
Make sure the country code and access number are correct,
Make sure there are no spaces between numbers,
Make sure you have credit in your phone,
Make sure the network isn't down for repair temporarily.
Dec 30, 2007 | Nokia 5300 Grey Cellular Phone
Buying
The sure Foot® cane and Sure Step® cane are now made by Sure Foot, Inc. and can be purchased at www.IcanWalk.com
Dec 13, 2006 | Mobility Sure Step Stand Alone Cane with...
Computers & Internet Logo
David Payne
David Payne
