My washer was washing fine then all of the sudden it just stopped at the end of the rinse cycle right before the final spin cycle you can hear the motor but it won't do anything and the tub won't move we used a shop vac to get the water out and my brother in~law tried to move the tub it would move alittle then stop like someone put the breaks on any idea what this is??
SOURCE: ESTATE TAWS800JQ1 WILL NOT SPIN
both of your problems are the clutch assembly if you are handy you can do this repair
SOURCE: How can I tell the age of my washing machine?
I would have to say from looking up your owners manual and the copy right date it is about a 2000 model.
SOURCE: what is capacity of my estate TAWS800JQ1 washer
You can go to;
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=TAWS750PQ&siteCd=WHRCOM
click on your model number for the owner's manual. This should give you the capacity.
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
We just had the same problem with our TAWS800JQ1.
I have the same problem, but if I manually push the drum then it will start to go.
I have the same problem, the washer stops at the end of the wash cycle.
I can slam the lid down and most of the time it will start again, if not I have to beat on the top of the machine. Do not have the model # but it is a Whirlpool Estate 7 cycle, 2 speed,heavy duty,large capacity,1/2 hp, double action agaitor,self cleaning filter,4 loads sizes,4 water tempatures. a number sm8280869 is inside the lid.
My problem is close but when it should get to the end of filling up after rinse cycle, it continues to fill and drain never switching over to agitate. The washer is only two years old. I see that there are no solutions posted. Did I buy a lemon?
