Question about Dishwashers
My hygena ahy-8122 dishwasher doesn't seem to be washing properly and the dishwasher tablets aren't disolving properly, I've been told this may be a thermostat problem
  • 641 Answers
SOURCE: ZANUSSI 695 Integrated Dishwasher
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Posted on May 26, 2006
SOURCE: Water not hot
I don't know if its hooked up to hot water or if it heats the water itself, but it was always hot and loads of steam at the end of the cycle, now there is no steam when I open the door and the dishes feel cold and wet! Not sure what's going on!
Posted on Nov 02, 2007
  • 1314 Answers
SOURCE: Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Posted on Jan 31, 2008
  • 10865 Answers
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Posted on Jan 28, 2009
  • 27 Answers
SOURCE: I have a bosch dishwasher which gets stuck on 1 minute for hours
Bosch dishwashers often have bad circuit boards.
Posted on May 08, 2009
Unused tablet
forget using the tablets. get the difi filtration system at www.dishwasherfilter.com. it will leave your dishes spotless and you do not need to add rinse agents or special tablets. guaranteed product or your money back
Jun 23, 2013 | Kenmore 24 in. 17482 / 17484 / 17489...
A couple of times I've found that the dishwasher tablet I'm using (Finish) hasn't dissolved correctly. I found it in the cutlery box the last time. I've been putting it on the 65 degree...
I am guessing you are using the Centigrade temperature scale ... which would be 149 degrees F. 149 is way hot in terms of regular house hold use. Probably just right for a dish washer.
I would expect most tablet detergent would disolve properly at this temperature and with proper water pressure in the machine. You should have plenty of both in this machine. May I suggest you give liquid dish washer detergent a try to see the results?
Jun 01, 2011 | Dishwashers
I went to take out my dishes out of the dishwasher this morning and the tablet was sitting at the bottom of the machine half disolved and most of my dishes weren't washed properly. What is the problem?
1. Check that water enters dishwasher.
2. Check that water is heated,tablet door will then open, this allows the propellor to shoot hot water at tablet to dissolve.
Apr 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
Soap tablets are not disolving in the drawer?
Unlike a dishwasher the drawer on a washing machine is for soap powder or liquid. Tablets won't dissolve in the drawer you need to put them in the drum if at all.
Dec 13, 2010 | Washing Machines
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
I have had my dishwasher for 3 years. In the past few days the tablet that i put in hasnt been disolving and washing the dishes. The compartment where you put the tablet opens its just the tablet doesnt...
I would say you are not getting any water flow since the water dissolves the tablet.
When starting it listen for the water valve opening and open door and see if there is any water.
If not it is probably the solenoid or a defective or blocked water valve which is not opening.
May 15, 2009 | Frigidaire Dishwashers
It sounds like you have a water supply issue. If you are on well water the screen in the water valve may be clogged. You can access this, remove it and clean it on most dishwashers. It is located in the valve where the water hooks up to the unit.
Apr 07, 2009 | Dishwashers
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
