Question about Photography
Lost the connecting wire from hotfoot to shutter
Purchased new at Pyle photo and stereo in Ames, Ia March 1979 ... Need the connecting wire that coordinates the flash to the shutter. This wire inserts (male prong) into the rear of the flash attachment and enters the front of the camera near the lense.
Solved
Posted on Nov 11, 2008
Zip code for 2311 Aspen Road, Ames, Iowa
2311 Aspen Rd Ames, IA, 50010 - Condos for Rent ' Zillow
www.zillow.com > Iowa > Ames > 50010
ZillowView 10 units for 2311 Aspen Rd Ames, IA, 50010 - Condos for Rent, as well as ... Ames Middle (assigned). 6-8 ... Nearby ZIP codes include 50012 and 50013.
2311 Aspen Rd Unit 101, Ames IA, 50010 ' Homes.com
Dec 16, 2015 | Computers & Internet
Where is repair shop for sewing machine. Euro pro in iowa
You might try Sears repair centers. They work on all types of machines even if you didn't buy them at their store. Not sure where you are located, but there is a service center for machines here: You can also call them at 1-515-287-4720 to see if they work on the Euro Pro machine.
SEARS SERVICE CENTER SEWING MACHINE REPAIR
SOUTH RIDGE MALL STE 2002,
1111 Se Army Post Rd,
Des Moines, IA 50302
Sep 15, 2014 | Husqvarna Sewing Machines
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
I am installing a Pyle PLMR87WB stereo into a Pyle PLMRCW3 Water resistant stereo housing. I am soldering the connectors and shrink wrapping them. Do I need to connect the memory wire. I do not want to run...
OK, time to go into cheat mode. You can always install a toggle switch to that wire. The only features I see you losing are that the time will be incorrect on the clock and it might not save your preset radio stations. All other functions are basic. Might I suggest a lighted toggle switch, this will help to remind you to turn it off.
Happy Wiring
Aug 13, 2011 | Pyle Car Audio & Video
I just installed an Pyle PLD70BT. Can't get any sound from speakers. Even tried an external speaker, still doesn't work. I installed this myself and have installed many stereo systems in the past, never...
May not be a problem with the installation, sometimes ya just get a bad one. If you have hooked it up to power, and ground, and attempted to use a speaker outside of the cars wiring, then odds are you just got a bad radio out of the box.. This sort of thing just happens man, but hey that's what warranties are for right?
Aug 08, 2009 | Car Audio & Video
I have Pyle PLTDN71, everything is wired properly , but it only plays music for 3 secs and cuts off. The problem is repeated everytime the unit or car is restarted... anyone ???
u probably connected ur power or constant to ur lights. if ur lights turn on ur accesry switch and than ur ight if ur stereo turns off thanu have tosee witch wire is connected wrong
Jul 09, 2009 | Pyle PLTDN71 Car Video Player
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Wiring troubleshoot
Make sure that your car is not amplified!! Some Celicas have an amplifier under the passenger seat. If this is the case, you will need to either bypass that amplifier and go directly to speakers, or you'll need the proper interface plug. The extra rapid heat build-up indicates that your radio is incorrectly wired (channels are mixed up)
Your Pyle radio may have an extra wire for "amplifier turn-on" or for "mute". A standard wiring harness for Toyota (Scosche part TA-02B) should work in dash behind the radio in non-amplified vehicles. If you are still having difficulty, please seek advice from a local stereo installation shop.
Aug 10, 2008 | Car Audio & Video
Photography Logo
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
