Question about Bulova Millennia With Vibra-Alarm 98A48 Wrist Watch
Small hand on Millennia not keeping time
Hello, The small hand on my Millennia isn't keeping correct time. It used to mirror the big hands when the alarm wasn't set. Not sure what's going on. Any help would be appreciated... Thanks! Will
From your book, start from square one. Second hand to 12 Pull crown to stop second hand.Set sub hands to duplicate main hands (correct time) Push crown in. I'm not that clever , I got the jeweler to do it for me.
Posted on Jul 23, 2008
Sell it off
Posted on Dec 06, 2007
Well, at least you know the minutes and seconds...
Posted on Sep 12, 2008
SOURCE:
My new eco drive watch has been charging for two days. It it keeping time but the big second hand does not move. Any advice or send it back?
Is your watch a chronograph? Many chronograph watches use the larger seconds hand only for chrono' functions such as stopwatch or countdown timer, and often have a small sub-dial for seconds.
If there are buttons on the side of your watch, you will probably find that pressing those will cause the large seconds hand to come into operation.
If it isn't a chronograph watch then send it back -it's faulty.
Dec 08, 2016 | The Watches
Second hand not moving
If the Chronograph is running, the second hand may be paused as on of your dials is recording seconds instead of the larger second hand. You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 | Watches
Second hand quits working (the small second hand)
the chrono second hand only works for one hour then stops,it's only used for timing purposes, see instructions on the link below ..
Apr 07, 2013 | Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
Feb 28, 2011 | Fossil Watches
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
Tissot PRS 200 My watch is not keeping time. It is not a batery problem. I have been told that it is because the chronograph is always working. How do I shut it down ?
Your true actual time second hand is on one of your subdials. That big "second" hand is really your chronograph seconds timer. It should start and stop when you depress one of the plungers/ buttons on the side of your watch.
Again, that big hand does not need to be turning all the time (or ever if you never use your advanced stopwatch/ chronograph). The true seconds hand is very small on one of the smaller dials.
Good luck, I hope that's all it is
Oct 23, 2009 | Tissot PRS 200 Wrist Watch
Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Jul 22, 2008 | Festina 16177 3 Watch
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 | Watches
Timex t28842
the small hand is the second hand the large one is for chronograph
May 08, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Bulova Millennia With Vibra-Alarm 98A48 Wrist Watch Logo
407 people viewed this question
Top Bulova Watches Experts
Arturs Kalnins
Arturs Kalnins
Chan Sun
Are you a Bulova Watch Expert? Answer questions, earn points and help others
