Question about Proscan 42LA30H 42 in. LCD Television
Channel 4 (Fox) has no sound. no problems with other channels
42 inche proscan flatcreen has no sound on Insight cable channel 4, which is Fox. Picture is fine and all other channels have sound.
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
SOURCE: PROSCAN 26" LCD TV with DVD won't show all the channels
bought 26 in pro scan tv can't figure out how to connect dvd player,craziest thing i've ever seen.please help
Posted on Mar 15, 2009
  • 92 Answers
SOURCE: olivia 42'' flat screen and cant get any cabel channels
make sure that you're not using a cable box. then when you do the channel scan, make sure that you pick cable instead of antena.
Posted on Jun 18, 2009
falter
  • 245 Answers
SOURCE: TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Posted on Nov 20, 2009
Hello, I somehow made it so I can only get channel 3.0 on my Proscan TV, I need to know how to get it on either channel 3 or 4, what do I need to do in order to change the channel?
Without knowing your model t.v. and other components, it's hard to say. For instance, if you have a cable box hooked up to it, then you would have to push the "cable" button on the remote to change the channels. If you have direct t.v. it would be the "sat" button. But without knowing, it's hard to say.
Sep 19, 2017 | Proscan Televison & Video
Proscan PLEDV 1945A-B will not recognize cable. Auto channel scan results in no channels found
Do you have the converter box to convert the incoming signal from digital to analog, you must have this to receive broadcasts.
Nov 04, 2016 | Proscan Televison & Video
Just bought a vew 65 inch LED toshiba and it says digital channel signal is weak. Why
Make sure you have the menu set on digital channels not cable. Set antenna to air to pickup digital hd channels.
Nov 27, 2011 | Televison & Video
What channel is the tv needed to be on to get cable, i push the wrong button on my tv then now is unable to get back to the cable channels.
Most cable TV systems that use a set top box or converter output on channel 3 or channel 4.
If you have HD cable service however, you probably watch on one of the A/V or HDMI inputs (Video 1, Video 2, etc.). Simply press the Video or A/V input selector, slowly & repeatedly until a picture & sound is seen and heard.
Apr 01, 2011 | Proscan 42LA30H 42 in. LCD Television
I Plugged in this cord in one of the channels to play my ipod so i can recored some parts of a song but when i played the songs they werent coming out as they are suppose to sound , it sounded all weird i...
The IPOD generates STEREO signals and you would have to use a 1/8 inch STEREO to 1/4 inch WYE cable into TWO channels of the mixer.
If you use a MONO cable it shorts out one of the sudio amps in the IPOD and will creates distortion.
When you use the two channels to accept the 1/4 inch plugs of the WYE cable, you will set the PAN controls of the two channels you use to opposite ends to maintain the stereo signal in the mixer.
Dec 27, 2010 | Behringer XENYX 2442FX Mixer
My tv wont pick up any channels i have a 42 inch lg tv and its connected to the household antenna but wont pick up any channels i have tried other ariels and still have the same problem?
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Jul 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
Proscan 42LA30H 42 in. LCD Television Logo
196 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
