Question about Westinghouse LTV-27W2 27 in. HD-Ready LCD Television
White flashing line on top of screen on some channels
How do I get rid of this flashing line on certain channels?
  • ssjunk Feb 11, 2009
    I have the same problem. Sometimes I can move the screen around via the remote and cover it up. Sometimes I can't. Comes back when T.V. is shut off as it resets screen position. VERY annoying. Its like a data feed your not supposed to see. something the channel uses?
Http://www.highdefforum.com/cables-connections/74145-flashing-blinking-line-lcd-tv.html
Posted on Feb 24, 2009
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Not getting full pic on certain channels
I've seen this problem before. Try to adjust the horizontal settings in the tv. you should be able to adjust the picture up just a bit and it will get rid of the lines. also if you are hooked up thru component or hdmi you should be able to press the # button on your time warner remote to fill the screen. Hope this helps.
Feb 10, 2009 | Philips Magnavox 42MF521D/37 Television
A horizontal line on the top of the tv when viewing some channels
that is normal, many tv's have this, just change the screen size, does this happen on hd channels too? or only regular channels?
Jan 21, 2009 | Vizio L32 32 in. LCD HDTV
White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Jan 07, 2008 | Televison & Video
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
592 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
