Digilogic digital set top box (DSTB1000) - No picture
I turn my TV to AV channel and all I get is a black screen. No picture, no sound. Standby LED is lit green. Function LED is lit red. The remote batteries are fine as I can still turn it on and off using the remote.
All of the lights are occasionally going off for brief periods too....i.e. turning itself off and then back on again.
We have been having some bad weather but surely that wouldn't cause this would it?
Is it doomed? I have had it for a while.
Shuttle83
  • 1139 Answers
SOURCE: 32 Toshiba TV no picture / bad pciture
Hello Suzid, It looks to me like you have a possible power supply issue (poor brightness on screen, shrinking of the picture, and initially no picture) This problem may put you in danger of electrical shock, so I would suggest that you not try to repair this set yourself. I would suggest that you take the television to a television repair shop.The power supply issue could be a low power or a high power supply problem.
Posted on Oct 08, 2007
Slinteriors
  • 8617 Answers
SOURCE: stressing out!!
Alba TVs are manufactured in Albainia and the service info is next to impssible to obtain. I would try to troublehoot the deflection circuits. Possibly horizontal output or one of the regulators.
Posted on Feb 26, 2008
  • 28 Answers
SOURCE: sony trinitron KV-27S42
Replace the horizontal output transistor (Q502) and check the electrolytic caps in the vicinty, unsing an ESR meter. PLEASE NOTE THAT THE TV TUBE MIGHT BE CHARGE WITH ABOUT 27,000 VOLTS.
Posted on Sep 18, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: digilogic dstb1000
the function light dose not represent a remote command, it simply flashes when it detects a infra red signal of any wavelenth. if the box is not turning on it sounds like a defective nor or nand flash rom. i believe that the box has a j-tag so maybe you re flash it?
proberly not
so inconclusion a defective flash means no os no os means the box wont work
hope this helps
Posted on Oct 31, 2008
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
Trouble with a Sony KDF-E50A10
sounds more like the video control board to me. You'll find that video drive is fundamental reason why these go 'black'
Mar 05, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Digilogic manual
Most likely it was a failed capacitor. Look for a leakey one or the top could be bulged.
Aug 29, 2014 | Digital Peripheral Solutions Televison &...
Sony bravia kdl-32v4000 has sound and back light but no picture or menu display
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 18, 2017 | Sony Bravia KDL-32V4000 32 in. LCD TV
I have a 26' led LG TV , and i am using a new set top box . when i am joining the tv from set top box and going in AV mode , its showing input blocked, i can not use set top box services. please h
Please provide a model number for this TV, I would have thought being an LED tv that you wouldn't be needing a set-top box as it would be digital already.
Apr 07, 2012 | Televison & Video
Tv turns on but there is just a black screen and no audio. It is not even 2 years old. Please help.
Most likely you are on the wrong source chanell. look for an AV/TV button. keep changing that untill you get to the TV stations. If you have a set top box make sure it is turned on. Also the appropriate AV channel will be the one that the set top box is plugged into.
May 12, 2011 | Vizio Televison & Video
Digilogic dstb1000
proberly not
hope this helps
Sep 01, 2008 | Televison & Video
Remote control code needed
i have a connect- it bd512 universal remote control i need a code to programme in to my tv it is a baier please help!!!!!!!!!!
Mar 11, 2008 | Televison & Video
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
