Question about LG 26LX1D 26 in. LCD HDTV
LG LG26LX1D Power issue ???
We have a LG 26LX1D. The unit is 16 months old and from the beginning when the TV would turn on we had sound but no picture. After tuning it off and back on the picture would come on. LG and the store where purchased would not do anything about it saying it was a poor signal issue, even though we have a new built house and cable signals were excellant. Now the power to the house went out twice in a row, the tv was off/standby and will not turn on. The standby light comes on red. I have the back of the tv off and the fan spins and there are 7 led lights on the main board DL1402, DL1401 and DL1403 located in the top left corner of the board are green. Towards the center right of the board 117, 118 and 119 leds are green and flash. Over by the cable card port there is 2 leds marked DL1101 and DL1102 only one of them lights up and it is red.
I don't have the tv hooked up to cable at this point in case that might have anything to do with the leds blinking.
If you could reccomend parts I would buy.
  • keithha Nov 13, 2008
    Yes, I checked the fuse. Not sure how to check the board..
  • LG Master
  • 19,396 Answers
To start download the service manual here:
LCD TV SERVICE MANUAL
Posted on Nov 12, 2008
  • Ginko
    Ginko Nov 12, 2008
    Follow the troubleshooting diagrams from page 16 of the manual.
    Genius:
  • 1,550 Answers
You have mentioned power problem .
Did you check fuse on the board it might have been blown .
  • SAM ANDERSON Nov 12, 2008
    Have you checked continuity in circuit board .
    This well help you to diagnosis where fault lies and you can replace that particular part .
LG LCD 26LX1D power blinking red ,all capacitor on power board are ok
try replacing relay on power supply had this twice on lg and goodman lcd tvs
Nov 25, 2012 | LG 26LX1D 26 in. LCD HDTV
I have an lg 26lx1d tv, suddenly red light bottom of screen was gone and then wouldn't turn power on.
  • Jeramie 36 solutionsMar 23, 2011
Replace capacitors c520 and c126 to get your power working again.
Also make sure that you don't have a broken green 3 inch jumper wire broke that lies under the heat shield in the top right corner. The wire should be glued to the board for stability. It sometimes breaks loose and will cause the TV screen to stay off.
Aug 28, 2012 | LG 26LX1D 26 in. LCD HDTV
I have an LG26LX1D tv, when I plug in the power cord, the red light stays on, but the TV won't turn on can anyone help?
hi,
Can you check is there is any variation in the red light when you press the stand by button. If it there is variation then you have to check the power supply of the tv.If there is no variation in red light then the mother board is faulty. if you need any more assistance feel free to contact me through FixYa.
ok
Aug 07, 2011 | LG 26LX1D 26 in. LCD HDTV
I need a user's manual for a 2005 LG26LX1D
  • http://dl.owneriq.net/0/0c04607e-100b-4de4-c18d-d8e7df3a6e46.pdf
Aug 25, 2010 | LG 26LX1D 26 in. LCD HDTV
My LG26LX1D won't power up. No Fan - Nothing
Check ur power source?Power supply board is dead.Replaced the power supply board will solved this problem.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | LG 26LX1D 26 in. LCD HDTV
My television LG 26lx1d doesn't turn on. I heard a
Mine did the same thing. It just seems dead, and ot lights at all. I tried another good cord, but nothing. Did you find the answer?
Feb 01, 2010 | LG 26LX1D 26 in. LCD HDTV
LG 26lx1d tv will not turn on. Power supply is fine. Remote control is working. Also tried on/off button on tv and tv does not turn on. Red light blinking on front bottom of tv near remote receiver.
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Jan 24, 2010 | LG 26LX1D 26 in. LCD HDTV
LG 26LX1D won't turn on.
My LG 26LX1D is the UA Version.
The solution for my problem was unclogging the Small Fan by the Main Panel, on the opposite side of the TV as the Power Board.
This is My Story.
The TV I found at the dump seemed good, but would not turn on.
Two LED's showed up on the front panel of the Television. First, the Red LED (on, off), then the Green LED (ON), then the Red LED (blinked) while the Green was still on.
I removed the back panel and saw that there were NO SIGNS OF BAD CAPACITORS on the Power Board. I plugged in the TV once more to see what would happen.
I noticed that there was a SMALL FAN which did not move when I plugged the power source to the outlet. This Fan was CLOGGED WITH DIRT.
I unscrewed the Fan from it's place and set it on a dish to act as a buffer against the main board. I then proceeded to clean it with a Vacuum Cleaner and a small Flathead Screwdriver.
I now own a FUNCTIONING LG 26LX1D-UA, RESSURRECTED!
Dec 31, 2009 | LG 26LX1D 26 in. LCD HDTV
I need to buy Powerboard for 26" LG LCD Television 26LX1D
There u go .!!
http://cgi.ebay.com/LG-Electronics%2FZenith-6871TPT303B-PCB---POWER-BOARD_W0QQitemZ390119483627QQcmdZViewItemQQimsxZ20091117?IMSfp=TL091117189007r1099
This product works with the following models:
LG Electronics/Zenith 26LX1D
LG Electronics/Zenith 26LX1D-U
LG Electronics/Zenith 32LP1D-UA
LG Electronics/Zenith 32LX1D
LG Electronics/Zenith 32LX1DUA
LG Electronics/Zenith 32LX3DCS-UA
LG Electronics/Zenith 32LX3DC-UA
LG Electronics/Zenith 32LX4DCS-UB
Nov 24, 2009 | LG 26LX1D 26 in. LCD HDTV
Power will not stay on
With a problem like this, I would use the warranty for the TV.
It's possible a circuit board failure has occurred and the TV is automatically turning itself off to protect it from further damage. Is normally called " Protection Mode " for most TVs.
Being that it's 2 months old, it should be under warranty regardless. I would recommend contacting the store of where it was purchased and have them help you with the warranty issue.
May 04, 2009 | LG 42PC1DA 42 in. Plasma HDTV
LG 26LX1D 26 in. LCD HDTV Logo
150 people viewed this question
Computer Repairing
Computer Repairing
