SOURCE: 54" cub Cadet mower... difficuly
I would srart by removing the negitive battery cable then the positive and clean posts and terminal ends with wire brush or sandpaper. I would then go through and one by one clean each cable you can get to on the starter and solenoid and any grounds to frame. Clean one at a time and replace as you go.If you have had the same battery for more than two years I would replace it to. A good battery will cost you about $40.00
Check gear on starter to see if teeth are badly worn. If so most of the gears can be replaced without replacing the starter. Make sure you have a good clean plug with the proper gap, clean fuel and air filter and vent hole in gas cap.Hope this helps you and thanks.
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
SOURCE: 2206 Cub Cadet
Yes there is one try looking under the footrest for a sticker with it on it.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
SOURCE: how do you replace the drive belt on a Cub Cadet
Just click this link.And follow the step by step instructions as per mentioned to replace the drive belt on lt-1050:---- http://technoanswers.blogspot.com/2011/04/how-do-you-replace-drive-belt-on-cub.html ------------- This should help.Thanks.Helpmech.
