Question about Maytag Neptune MDE5500AY Electric Dryer
Intermittent heat on maytag ldg8606aae dryer
Maytag dryer ignites and heats, then clicks off after 20 seconds or so. It will cycle back on after few a minutes, but only for another 20 seconds, or so. Only slightly warming. Vents are clean, gas has a good flow. Any Ideas. thanks
  • Lumber Joe Dec 22, 2008
    I have the same exact problem. Would you be willing to explain how one might replace the coil? Thanks
  • 41 Answers
Your coils are most likely bad. if you are up to tackling the job yourself, I can help. otherwise, you will need to call a repairman. Joe
Posted on Nov 18, 2008
Intermittent heating on different cycles?
After a 12-year service life it probably is time to retire your Maytag dryer.
Feb 23, 2014 | Dryers
My dryer turns on, will click then the fire ignites, but goes out after a few seconds, so it is not staying on, and it takes two and three cycles for my clothes to dry, is it the igniter?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag gas dryer will not heat?
Remove the lower front panel by prying it away from the cabinet.Start a dry cycle and look for a glowing red igniter in the compartment behind the door you removed (keep your hands away from moving parts).If you don't see a glow after a few seconds you may need a new igniter.
Oct 09, 2009 | Maytag Dryers
Maytag Dryer - runs but no heat
it needs a new element behind the drum
Sep 19, 2009 | Dryers
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune dryer heats up sometimes
hi there,
this is an older style dryer that has an igniter. check the valve itself, you may have an intermittent operation.
thanks
Sep 10, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 14, 2007 | Maytag Neptune MDE5500AY Electric Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
205 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
