Question about Sony KV-32FV1 32" TV
Intermittant power down
This problem actually started two years ago. Took it to the local shop and cooked it for two weeks--no recurrance. Then a week ago, started again. Thought I might have faulty AC outlet and changed recepticles. Seemed to help for a week, then started again. Symptoms: Set will spontaneously loose video and sound, displaying only a green raster with retrace lines for 1-2 seconds. Then shuts down (relay click is audible). On rare occassions it will spontaneously power back up within seconds. But most times, it requires restart with the remote (power button works equally well). The restart could last for hours, or (more recently) the problem resurfaces immediatly. From the web traffic on this subject it seems to be quite common with Sony Wega's. Unfortunatly among all the complaints, I find no solutions. Year's ago, in the old tube world, I did a little TV repair work. So, I ordered up a SAMS (#4933) on this unit and believe from reviewing the schematic that the problem would most likely be on the "G" Board (power supply/degauss). And while I acknowledge the possibility of a cold solder joint, the cost of a replacement board is around $150. Since I no longer have any test equipment, just looking for some forum support that my "hunch" is a good enough bet to spend $150 on. I should also mention that I taped over the IR sensor, just to insure no spurious input was turning off the set--made no difference. Any suggestions most appreciated. This has been driving me nuts for two years.
  • Ron Hintze Nov 22, 2006
    Re; the use of refrigerant. I've used this technique successfully on overheating components. However, in this particular problem the set works normally, sometimes for hours, but occassionally for only minutes, then faults and shuts down. So, what ever component is failing allows less than 2 seconds of response time--no way to apply refrigerent to anything in that short a period. But thanks for the reply regardless.
    Scholar:
  • 68 Answers
I have the same problem with my computer monitor. this is the reason I have not answered problems for two or three weeks. I took the covers off to monitor the power supply, but it would not then go wrong. The fault is collapsing picture in my case, but it recovers nearly always. It has not got as bad as your TV. The best way to deal with it is to buy a can of refrigerating spray. If you know what is power supply, then cool the individual transistors or integrated circuits when it has been working for long enough to heat the components. This may cause the problem to occur. Then you can change that component. If this does not work then carefully attach wires to the various power supply voltages, so they come out of the casing. The casing can be put back so that it can get hotter. Terminate the wires in a connecting block, including chassis (Ov). Be careful as the mains voltage may be present on the wires, due to a live chassis. Connect a voltmeter or voltmeters to the connecting block, and you will see which voltages are collapsing, after you switch on. I will have to do this, so good luck!
Posted on Nov 17, 2006
    President:
  • 3,130 Answers
I would check for bad connection and or componets in the sweep power supply and the main power supply. Pay special attention to the lower voltages like the 9, 12, and 15 volt sources. These sets these days do not pay to replace the entire board assy. you may, if you can narrow it down, contact PTS, a company that repairs television boards, at http://www.ptscorp.com, and see if ythey will repair the board you want. Good Luck PS plese dont forget to rate this thread.
  • Larry  Dillon
    Larry Dillon Mar 24, 2007
    Oh geeez i did not catch that before. What your discribing is an intermeittant picture Tube.
Samsung HC-P4752W Does Not Turn ON
The proble you have is an intermittant power supply or sweep power supply. Unless you can find a bad connection on the power and deflection board, this could be a very difficult problem to find. I have ran across this problem a couple of times, and after spending countless hours troubleshooting, I replaced the main board and all the problems were taken care of. The board part number is at samsungparts.com and I found the board for you. it is located here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP94%2D01266A&search%5Fmodel=HCP4752W Good Luck
Jul 04, 2007 | Samsung HC-P4752W 47" Rear Projection...
I have an E1060 drop in. The unit was purchased three years ago, but major delay in construction. Installed a couple months ago, all was fine. Have yet to cook on this grill. Two weeks ago, went to use,...
Dan, did you check the circuitry and relays to the motor, as was suggested on March 29th? If the motor can't get power it won't work. It seems, that this may be the problem, since you took the motor apart and there were no broken gears and all other electrical devices work. The other resolution was to contact R.H.Peterson Company, the manufacturer for more information, if all else failed.
Mar 31, 2011 | Fire Magic Echelon E1060s2E1P51 Stainless...
I have an Acer 24" wide screen LCD monitor. When it sits idle for awhile it puts itself into sleep mode. Usually you would only need to touch the keyboard or mouse & the monitor would revive, a week...
jlichtenegge, Wish all lcd monitor problem descriptions where as good as you have done!!! Here are some suggestions. Use ACER warranty first if valid!!!! If warranty not an option, then do cash+old unit swap for a refurbished same model if ACER has a swapout program for infantile failed units. (short SMPS/CCFL inverter board lifespan) If monitor DOWN TIME is super critical then you or local electronics technician will need to DIY repair unit by resoldering the thermally fractured intermittant soldered to board component lead that is causing "switch-mode-power-supply" to go into full or partial shutdown mode. You may need an inspection grade microscope to visually locate the oxidized intermittant connection. Let me (lmistyrel on aim.com) know what you intend to do fmi Hope this helps. Read more of my fixya profile to get more of a handle on this type of failure. Bye for now.
Jan 26, 2010 | Acer Computers & Internet
Battery is draining while being parked
How old is the battery? have it checked at the local part shop like Advance Auto or Auto Zone etc -
Take down the Vin # and call the local dealer - - ask about recalls and Service bulletins.
Oct 15, 2009 | 2006 Ford Mustang
GE JE1860BH04 microwave--light works but nothing else
You`ll probably find that it`s the interlock switch on the door latch. When the door is closed, the hooks that protrude from the door enter the slots in the oven casing and press down on the latch switches. DO NOT over ride these switches, replace them or get an engineer in to check them. Ian
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Mazda MPV 2003 Turn Off On The Highway
I had a similar problme to this years ago on a VW that I was driving.
I took it into the the shop and they said that they couldn't find the problem either and couldn't get the car to do it when they tested it.
Then a few weeks later it happened to me again as I was out in the country and an old farmer stopped by to help.
He discovered that the wire leading to the alternator was too thin. It would over heat and then shut the car down. Once it cooled off, it would start up like nothing.
He got a larger piece of wire and and changed it for me right there on the spot. It took about 5 minutes and I was off and running.
I never had the problem again.
I don't know if this is the same thing that you have, but it's worth a look.
Good luck.
Oct 22, 2008 | 2003 Mazda MPV
Motorola z8
for bpo solutions surf www.lexicon.com
Jun 13, 2008 | Motorola Lands Phones
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
PDP-4330HD
This exact same problem happened to me 2 weeks ago on my Pioneer PDP-4330HD, and it did indeed turn out to be the power supply. The good news is, you can get it fixed for free, because Pioneer actually recalled the power supply in this plasma and others a couple of years ago.
Here is a link to the announcement on their website concerning the recall. They say that they will do a free in home replacement of your power supply, but when I called the local pioneer repair place, I was told I would have to wait three weeks for an in-home appointment. I ended up taking it in myself, and it was fixed for free 2 days later. Now it works perfectly.
Here's the number to call Pioneer in case the link goes down:
1-800-421-1404
Nov 10, 2005 | Pioneer PureVision PDP-4330HD 43 in....
Sony KV-32FV1 32" TV Logo
174 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
