Question about RCA RTD 130 System
TV will not turn on--it tries green light turns on and off 3 to 4 times then quits
RCA 1990's 36" Picture tube TV was working fine. I went to turn it on and it would not. Acts like it is tryin--green light turns on and off 3 or 4 times then quits. Screen, however, remains black. Also there is not noise or static. I have tried unplugging. It has a detatchable power cord. I noticed that the power cord has 3 holes where prongs should fit and in the tv there are only two prongs. Could this be it---if so what do I call that part--to order it and install it? Thanks for any advice. The model # is F35750ST. This was a very popular model at the time and could be purchased almost everywhere.
  • Anonymous Mar 13, 2008
    I AM HAVING THE SAME EXACT PROBLEM
I was wondering if you have looked through your service manual or owners manual for troubleshooting the problem. If not you can get service manuals online at http://www.servicemanuals.net/results.aspx?type=SM&brand=424&model=F35750ST Quinn
Posted on Nov 03, 2006
SOURCE:
Can dust build up on a picture tube's circuit board cause them to overheat and shut the tv down.
dust will not cause an issue like this in this type of set--RCA? it means a short of some type exists and the set shuts down or blanks the tubes--all you have described as far as appearance is normal.
RCA sets like this can be difficult to repair and also if you Google the model number you will see they have a lot of "problems".
Apr 23, 2012 | Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
RCA Model P46924 I screwed up
Check connections at the HV distribution box (where the leads from the flyback connect to) and make sure all of these are in solid first. It sounds like a device is burnt open, since the over- current protection is not activated. This would allow the TV to still turn on, but with no picture. Of course you had installed a fuse too large, so that could explain that too- don't do this, you might have made the problem worse by burning out more components. Could be a bad horizontal deflection transistor or flyback transformer. Transistor p/n 2SC5148, flyback 239111 for this model, RCA P46924. You can find them on ebay for cheap.
Oct 29, 2007 | RCA P46924 46" Rear Projection Television
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
RCA RTD 130 System Logo
175 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
