Question about Panasonic CT-36G34 36" TV
No volume or picture
When my tv is on there is no volume or picture but you can hear static for about 10 seconds.does anybody know whats wrong with it?
0 characters
1 Points
ALBA tv screen turns itself off, but the volume stays on, what's wrong with it? how do I correct it?
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
May 11, 2012 | Proton MM2701VT 27" TV
Turn it on i hear a click but no picture, about 10 seconds later the tv clicks again like it's turned off
Sounds like your tube is out. To fix it would cost more than the TV. Try to unplug it overnight and try agian. Post again when you try that and we can try something else.
Mar 17, 2010 | RCA 27V530T 27" TV
Got an rca 32v434t, plugged in hooked up, and it
we would need more information:
has TV worked before
how many hours has TV been used
I have seen this 'ShutDown' on many failing monitors..
Typicaly the Power Supply circuit in your TV
have 'Over Current' detection\protection
and your 10 second is just about how long somthing is probly taking to either:
over current and shut down
or more specifically:
one or both things wrong with it:
bad electrolytic capacitors ( maybe )
but if it's a perfect picture for all 10 seconds then probobly some specific semiconductor or module is: 'Heating Up' then 'OverTemperature' and failing in a manner that causes an immediate overcurrent condition, shutting off the TV.
- give more information
- if capable of safely removing the back of the TV to allow for inspection...
by the high voltage that remains stored inside the tube, even after power has been removed !
then pop her open and have a look at
the PCB's ( circuit boards )
if somthing has been running hot and has led to this type of failure; then your circuit board will be discolored near the mounting of that device... You may even notice a burnt pcb smell at that area.
somtimes you can find these semiconductors or modules in catalogs or online ( OfCourse )
and yourself or sombody with sufficient knowledge of soldering and the
' Potentially Life Threatening Hazzardes '
that exist around CRT monitor repair....
... can go ahead ad replace the suspect part.
Jun 16, 2009 | RCA 32V420T 32" TV
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
The tv has a static sound and picture has vertical lines but is still visible. Heeeeeeelllllp. Thank you.
Jul 21, 2008 | Philips 19PR19 19" TV
Have you tried unplugging the set for 30 seconds? If it does it in the future again I know a more permanent fix but not specifically right now.
Dec 28, 2007 | RCA P46922 TV
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Volume control
If the picture is oK and no sound. The first possible problem or trouble is the speaker. It may be broken, open, otherwise defective. Second is the phone jack on your TV set. Third is the amplifier. Just check all this mentioned parts.
Jul 10, 2007 | RCA 32V420T 32" TV
Panasonic CT-36G34 36" TV Logo
20 people viewed this question
Top Panasonic Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Panasonic Standard (CRT) Television Expert? Answer questions, earn points and help others
