Van was driven to a store and returned to van to start , ignition just turned over would not start
Open gas cap and turn key forward and listen for the fuel pump hissing noise. If its not there the fuel pump is out. (OPTION) Take heavy object like a club or tire Iron and bang plastic fuel tank in the middle. Several blows will be required. The idea is to shock your fuel pump into working. If it works then get it to a repair shop because It most likely will die again.
Testimonial: "Thanks I tried to find a fuse for the fuel pump only could find a relay is there no fuse"
SOURCE: 95 gmc safari replaced fuel filter van ran great now wont start
Since you replaced the distributor, are you sure it's properly timed? Hook up timing light and try to crank. It should show you where your timing mark is. It will also verify that you are getting spark.
You need to start a systematic check. Is it electrical, mechanical, fuel related? Need to do more checking and maybe we can get that puppy going.
Good Luck
SOURCE: van won't start, maybe fuel pump, where is it
You will need to find a junction box in the engine compartment where some fuses will be located. There should also be some relays in the fuse block. Under the cover should be listing of where relay is located. you can jump a sire across the pins in or to see if fuel pump runs. If it does then the problem is at the relay. If it doen't, problem is at the fuel pump. Problem with that is that the fuel pump is in the tank and the tank will need to be dropped in order to get to it. Good Luck
SOURCE: 95 gmc safari problems
yes delivers the fuel bat is not enaf pressure replase fue pomp end you be ruaning agein
SOURCE: 1997 GMC Savana 5.7 L conversion van. Cranks but wont start
Fuse? Check crank position sensor.
SOURCE: Van will not start. It Cranks and the fuel pump
wont turn over??sounds like the timing belt has broke and pistons hitting the valves
