Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Icemaker problem crushed only not cubes
Have a TFX24PRXBWW GE Profile Refrigerator with icemaker. It stopped dispensing cubed ice. It makes ice but it will only dispense crushed ice through the door. I replaced the MODULE TIME DELAY (Control Board) EAP304236, thinking this would be the fix but, alas it was not. I do not really know how the dispenser works, but it look like the auger only turns in one direction. I think it needs to reverse direction in order to dispense cubes. Any ideas on what I should replace. Your help would greatly be appreciated.
  • 2 more comments
  • Anonymous Mar 07, 2008
    The problem is the solenoid for the trap door for cubes. On the end of the solenoid there is a plastic piece that pulls the lever for the door up. It is broken. 4 (corner) screws remove the unit from the back wall, remove plug (electric) then you have access to the part.
  • Mikie227 Apr 10, 2008
    I have a Kitchenaid KSFS25FKBT01 with same problem (crushed ice, no cubes). Took out ice bin, kept door switch closed, had wife press both "cubed ice" and "crushed ice" buttons. Nothing moved in the opening where the control lever goes. I assumed it's the solenoid until I read someone else had a door wiring problem instead of the solenoid. Is there any way to verify it's the solenoid and not the door wiring w/o tearing the back panel off?
  • Anonymous Aug 08, 2008
    Replaced the control boards
  • Anonymous Nov 15, 2008
    i have the same a kenmore 253.54462400
Whenever the ice tray is removed, you need to reposition the cube/crush selector rod that is attached to the bottom of the ice tray. This rod swivels: down position for crushed, up position for cube. At the back of the freezer, there is an opening to which this rod inserts. It houses the solenoid for cube/crushed operation. For cube position, the horizontal plastic piece is slightly above the center of the opening. Slide out the tray until the rod is past the solenoid. Pry the solenoid down as far as it can go. It is spring loaded and will not break. (If it doesn't feel like it is spring loaded, stop here and call a repair tech.) Now swivel the rod on the tray up and slide back in making sure the end of the rod is ABOVE the solenoid. DONE!!! Now you have cube ice. Good Luck.
Posted on Sep 22, 2009
My Frigidaire's fix was the basket was not installed right. the rod that controls the flap was not positioned right inside the solenoid control arm.
Posted on Oct 06, 2008
I have the same problem. I guy I know is a Frigidaire Service Tech. I asked him about this problem and he suggested that the problem is likely the solinoid that switches the dispenser from crushed to cubes is gone and is stuck on crushed. That's fine but I have no idea how to take the door apart to get at the problem. Unforunately this guy will not fix it for me without having to pay him to do so. So I thought I might give it a try if I could figure out how to get at the problem. Can you advise me how I would open up the door to fix this? Gord
Posted on Jun 03, 2007
I looked at the plastic piece the solenoid was moving (from Guest's comment 03/07/08). Pushed the plastic piece up (had to push pretty hard) and it reset the solenoid to its' start/beginning position(-?) Plastic piece came back to lower position - was free to move up and down. The solenoid is working now (hear the loud clicking and see it pulling the plastic piece up) to get cubed ice, instead of putting it thru the crusher.
Posted on Mar 15, 2008
I'm having the same problem. On my fridge there is no 'crusher motor.' The auger assembly ends with the crushing blades. To get cubed ice there is simply a trap door that opens allowing ice to not be crushed. A switch opens and closes the trap door by lifting and lowering a rod. It makes sense that this trap door is controlled by a solenoid. I just hope that this is located in the front of the fridge and not the back.
Posted on Jul 22, 2007
What i did was keep the white flap that opens for cube. well find some way to keep it open without blocking the path of the cubes. i did it and know i have all cubes:)
Posted on Aug 14, 2008
We had the exact same problem on our KitchenAide KSFS25FKWH00 Side-by-side, and it turned out to be a damaged wire in the wiring harness that connects the door to the fridge. The damage occurred at the bottom of the door, where the wiring harness was secured by a cable-tie to keep it out of the way of the bottom grill. The cable tie caused a sharp bend in the harness, and repeated flexing at the same point eventually broke the wire. Our appliance store repaired it under warranty with a complete new door from KitchenAide, and it came with revised instructions to NOT use a cable tie, but just to exercise care when removing or reinstalling the bottom grill. Martin Step mstep@greenval.com
Posted on Aug 26, 2007
  • 237 Answers
Sounds like the crusher motor runs no matter what Ice you select. Look into why the crusher motor is running even when you want cubes. Could be a couple possibilities (hard to tell without being there looking at it ya know?). The crushed ice switch/control board could be defective (stuck in crush everything mode...). Try this link and click on the small diagram to enlarge it, that may help you visualize the workings of the unit. http://www.partselect.com/ModelFrames.aspx?ModelID=744608&ModelNum=TFX24PRXBWW&mfgModelNum=&ManufactureID=2&Selected=00005649i03&Position=0&mfg=GE&Type=&Mark=1
Posted on Nov 10, 2006
4 Suggested Answers
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Posted on Mar 28, 2009
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Our GE Monogram Icemaker will only dispense crushed ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Only will dispense crushed ice, no cubes.
Sounds like the piece which lifts up the crush/cube actuator behind the ice bucket . Will have to be replaced with 1 piece (plunger AND actuator ) .
Jul 18, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice cubes will not dispense, but crushed ice will. GE Profile TPX24PRYA
If the auger motor turns in either setting we know that the auger motor is OK, and if it does not turn in both crushed and cubes that leaves a problem with the WR55X129 time delay, which is the part that you switch to go from cubes to crushed to water.
Dec 06, 2008 | Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
2,918 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
