Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
No sound and no picture.
My TV cut off and when I tried to turn it back on it had no sound or picture yet there was a low whistle click noise and the power button on the tv would light up when tv was on. How can I fix this myself. I'm very handy with electronics.
  • man38 Nov 12, 2007
    I have a similar problem. Have sound but no picture
  • csandova70 Nov 14, 2007
    My unit does exactly the same thing. Mine sort of chirps and there is no pic or sound, but the light on the power button is on.I already had it fixed once for the convergence problem. (cost me over $200) Would love to fix it myself if I can. If not, I will go to WalMart and buy a flat screen 42" for $800 instead of paying another $200+ on this one.
    Thanks for your help in advance.
    Genius:
  • 1,153 Answers
Look for the vertical output, it should be a 7 pin transistor located on the defection board, meaning the board with the highvoltage transformer on it. Should be on a heat shield standing up(black)
Posted on Aug 15, 2007
SOURCE:
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
Our LG tv has started making a vibrating whistling noise when you first cut it on, you can hear it get faster and faster, then slowly goes away. Also, I've notices over the past few months the picture...
It sounds that the horizontal output section circuit to your TV is to be checked. It is really a skilled work. Contact any service technician.
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
Jun 09, 2012 | Sony KP-53V80 53" Rear Projection...
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
No picture no sound just a whistling noise
maybe the flyback transformer or horizontal output ic
Jun 01, 2009 | RCA 27R411T 27" TV
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Continuous low whistling or thin buzzing noise
The high pitched sound is an indication that theres a short most likly in the Hi voltage sweep section or power supply and with out the proper training you should not even take off the back as there are no user replaceable parts inside of these sets. All the parts are soldered in and you can not look at them and see that they are bad.. its almost like when your check engine light comes on you look but what do you see without a computer to read the on board computer vto see what the problem(s) are. Take the set into or call a pro to assist you with this repair. good luck
Jul 25, 2006 | Panasonic CT-27G33 27" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
213 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
