Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Yellow lines Hi and thanks for the help. I have yellow lines, somewhat fingerprint looking, in a 8 x 10 square in the upper left corner. any suggestions?
  • gerlich8725 Oct 06, 2008
    I too have yellow lines on the left of the screen. The lines look like a maze. What was the solution? I have the 50 inch WEGA.
  • jimfishersf Dec 29, 2008
    I have this same problem. Who do I call to work on this and do they come to your house or do I need to move the TV to the shop.
    Did the other folks who posted find an answer?
    Thanks,
    Jim
    President:
  • 3,130 Answers
This is an LCD type projection set, so your problem COULD be a bad light filter on one of the LCD's in the light engine, or something is on one of the mirrors inside the set. Replacing or serviceing the light engine inside these sets should only be attempted by a trained service tech, because of the equipment thats needed to do this repair. good Luck PS please dont forget to rate this thread.
Posted on Nov 03, 2006
SOURCE:
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
SEVEN SQUARES ON A PIN BOARD I CANT GET IT
Hi there,here is you answer,enjoy
There are 6 lines of pins
On each line they are in different positions
So for this occasion we are gonna number these from 1-28,from left to right then from top to bottom
We will give each square a colour and a number
1*Large blue square join the 4 corners at pins 8 to 16 to 23 to 28
2*Large yellow square join at pins 4 to 12 to 21 to 27
3*Small red square join at pins 17 to 22 to 24 to 26
4*Small brown square join at pins 14 to 18 to 20 to 25
5*Small light blue square join at pins 5 to 9 to 11 to 15
6*Small white square join at pins 1 to 2 to 6 to 7
7*Medium white square join at pins 3 to 10 to 13 to 18
Hope this helps its the easiest way i think i can describe it
JonnieC
Jan 06, 2010 | Nintendo Professor Layton & the Curious...
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
Grid surrounding cursor and desktop icons
You have accidentally enabled "Universal Access"
Open System Preferences from either the dock or the pull down menu under the Apple in the upper left hand corner of your screen.
In System Preferences the 4th line down should have icons for "System" one of those icons (usually the right most) will be a blue circle with a person in it. This is "Universal Access"
Open Universal access and turn voice over and zoom off.
Feb 28, 2009 | Apple iMac G5 Desktop
Black screen with flashing small line in upper left corner
PULL OUT THE MEMORY AND PUT THE OLD ONE BACK IN AND SEE IF YOU FIX THE PROBLEM.
Feb 12, 2009 | HP Compaq d530 SFF PC Desktop
Arched picture on Sony KV-34XBR800
Your TV has problem in Pin-Out area. I know its technical term but I have no other words to explain it. TV needs qualified technician to fix it.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
