Question about SanDisk Sansa e130 MP3 Player
Sansa e130, with cracked screen, blocks on turn on...
Ok, so I was at a friends place, and I was syncing something...when his PC restarted, I'd left my mp3 plugged in...and chkdisk started...It finished and now it won't start up...there was a 'chkdisk log.txt' in the player root, I deleted it, and it's still not working...tried cutting the music.lib file out, still doesn't work...any Ideas?
Jessamole
SOURCE: Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Posted on May 09, 2007
SOURCE: My mp3 freezes up..can anyone help??
plug the sansa into your pc. go to 'my computer' and right-click the sansa. click 'format' and click 'quick format' on the pop up screen. this will effectively reset your sansa, and give you a fresh start.
Posted on Feb 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: SANSA c140 not sychronizing
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE: Sansa E260- Cannot delete songs/ won't respond to modified files.
In order to sync the files with media player the device must be in MTP mode MSC mode is used for drag/drop file updating. try setting MTP and then sync it or just open the drive file in my computer in either mode to update the file list.
Posted on Aug 21, 2009
Thermo King
  • 593 Answers
SOURCE: SansaDisk Sansa m250 (2GB) "Finalizing update"
You need to go to the Sandisk support site and down load the Updater program. Run the updater on your player. This in a way reinstalls the software on the player kind of like reinstalling the operating system. [
Posted on Jul 20, 2010
Screen
You can try the "soft" fixes I have suggested below, but if your screen is actually cracked, then you will have to get the player replaced. There are no repair services for cracked screens on any mp3 player.
-Tha Mp3 Doctor
Jun 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Stuck in language mode
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
Thank you for the help in reformating my sansa e140. It worked perfectly!!!
Jan 18, 2008 | SanDisk Sansa e130 MP3 Player
Sansa e130
ok, for everyone with e130 "keeps getting an I/O device error, only language screen, than something about 4MB memory..." problem, I just spend six hours of my life trying to solve it and fix my dad's e130 and I succeeded ;)
so, step by step, how EXACTLY I did it:
0) my system was windowsXP SP2
1) remove the battery
2) keep holding the menu button and plug in the usb, keep it for a few seconds more, untill the system will tell you it found a stmp3500 and want to install the hardware
3) allow it to reach windows update for that matter and install the drivers
4) now you have new device that is called "Player Recovery Device Class" you can check it in device manager (Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager)
5) and now is time for flushing new firmware...I managed to find two versions of firmware for e130:
1.0.101e - http://www.sandisk-karty.cz/sandisk-katalog/sansa-e100-series-mp3-players/dokumenty/
2.0.0.01e - http://www.sandisk.com/Retail/Default.aspx?CatID=1295
6) I tried both of them in many different combinations and finally one and one only miraculously worked for me and that was the one when
I HAD THE SD CARD IN THE MP3PLAYER, THE PLAYER WAS RECOGNIZED AS "Player Recovery Device Class" BY THE WINXP AND I STARTED EUROPIAN sansa-2.0.0.01e.exe !
PS: i don't think that there's a big difference between europian and american version of firmware I mention it just to be accurate about the situation. and big thanks to anonymous guy who turned me to right direction with stmp3500. hope that help to others ;]
Oct 26, 2007 | SanDisk Sansa e130 MP3 Player
Broken screen
Afraid Not - these things don't repair- just buy another.
Jun 21, 2007 | SanDisk Sansa e130 MP3 Player
Deleting 4MB of memory
Make sure lock is not enagged
-Tha Mp3 Doctor
Feb 08, 2007 | SanDisk Sansa e250 MP3 Player
Sync to player and memory card without duplicates
I got this from:http://www.livedigitally.com/2005/06/27/sandisk-sansa-e130-the-micro-version-of-the-ipod-mini/ Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
My LCD is not working!! HELP!!!
The one thing I can suggest is that something must have cracked the screen or disconnected the wire leading to the screen and it is intact enough that the back light will go on. The only thing you can do is send it back and if it under warranty you will receive a new mp3 player. Also make sure you have all the songs on a file on your computer.
Sep 04, 2006 | SanDisk Sansa e130 MP3 Player
Sansa e130
Does the battery need replacing? My screen is cracked and it appears the battery discharges quicker than normally. For now, I check the voltage on my rechargeables before installing them so that I know they are good. Try putting one song on to see if that will play?
Aug 07, 2006 | SanDisk Sansa e130 MP3 Player
My sansa e130 dosent wanna turn on, please help
if you find out whats wrong tell me i have the same problem e-mail me at zdittric@telus.ent
Jul 31, 2006 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa e130 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
